Editng APL file in arcstudio
1340
07-31-2012 03:04 PM
EricJohnson
Hi, I created a shapefile in arcmap. Then in arcpad studio I created a form to deploy into my trimble geo xh gps unit which runs arcpad software.  I tested out my form for the information I was gathering with my trimble.  I used a combo box for one of my labels and I decided that was not the appropriate choice for the information I was gathering.  I checked in the information that I collected into arcmap, then I went back into arcpad studio to try and edit one label in the control box to a different style.  I deleted the combo box in the edit window and tried to bring over a different box to put with my label and the "FIELD" in control properties is not open for me to choose the label I would like to attatch this to.  Is it editable?  I hope so because I would rather change this one label vs. re-creating a whole new form. Any ideas?
Jason
Tags (3)
DeniseKing
Hi Eric,
Are you referring to modifying a LABEL or TEXT control? For more information, please review the Customizing ArcPad Forms > Customizing forms: an overview in ArcPad Studio Help for detailed information on form controls. What type of control are you trying to modify in ArcPad Studio?
[ATTACH=CONFIG]16548[/ATTACH]
In ArcPad Studio Help, the Redlands sample is based on shapefiles and APL files and is used in the Quick Start Tutorials > Tree Inventory. Exercise 2 is Custom Forms and covers this topic nicely. If you still need help modifying your Edit form, please contact Esri Support and submit a support request so you can work with an ArcPad specialist via Chat, Phone, Email or Webform to resolve this challenge.
Cheers,
Denise
EricJohnson
Thanks, I looked at the help section like you suggested.  My issue is I created a combo box and decided that is not what I want to use.  I try to clear it and bring over the default configuration but can't accomplish that.  I delete the control(combo box) and then drag over the label box and go into the control properties but I cannot choose a field (drop down is not an option) to assign the box of the attribute I want to work on.  I am trying to avoid creating more work than I actually need to do.
