Drop down menus in ArcPAD 7
3485
01-10-2013 01:36 AM
GeospatialTechnology
We've been recently loaned a dGPS unit with ArcPAD 7. I have previous experience using Digiterra Explorer and havnt used ArcPAD before. What I was wondering is how do you create drop down menu's in forms? I've set up a shapefile with several attribute fields but want some of them to have a drop down menu to select when a new point is recorded. Is there a quick way to do this or does anyone know where I can find a userguide?
Thanks for any help.
Tags (3)
JuanLuera
Hola Mark,
I was doing some research for you on your latest request, for creating drop downs from within Application Builder. I was able to locate the following documentation, which will guide you through creating these for your shapefiles.  Gracias, Mark!
What's New in ArcPad® 7.1 and
ArcPad Application Builder 7.1
Page 10
http://downloads.esri.com/support/whitepapers/pad_/whats-new-arcpad71.pdf
Thanks for this juan5934.
I have figured it out now.
Information can be added in Quickform
