Drop down calendar on arc pad 10
2519
01-14-2013 11:39 AM
DanielKim4
Hi there,
I have created several drop down menus for each field using arc catalogue and transferred them onto Arc Pad 10. However, my date field???s drop down calendar is not working on Arc Pad although it works just fine when I tried it using Arc Map 10.
The attached file is a screen shot of my current Arc Pad 10 form.
Your help would be appreciated.
Tags (3)
JuanLuera
Hola Daniel,
I just walked through the following work flow from within ArcMap using the sample Poles feature class from Riverside database. I created a new date field, and checked it out, then opened the apm within ArcPad on the desktop and added a new feature with the date field available. Gracias, Daniel!
Work flow:
1. New mxd
2. Added Poles from Riverside database
3. Added a new date field (my_date)
4. Save the mxd
5. Checked out for Disconnect Editing  the layer
6. Made my axf and amp
7. Opened the apm on the desktop within ArcPad
8. Added a new feature and my date field was available
9. See attachment
ArcMap 10.1 with ArcPad 10.0.4
DanielKim4
Thank you so much 🙂
