Delete record from DBF table.
8381
15
12-16-2010 11:58 AM
JayKappy
I cant figure out how to delete a record from a DBF table....I have a few DBF lookup tables with my application that I have code that allows the user to update and create new rows in the DBF table.  But now I want to give the user the ability to delete recrods as well...
I am tryign this with NO success
Any thoughts?
   Dim objRS3, objSelLayer3, objEFPageOneControls3, objEditForm3
 Set objSelLayer3 = Map.SelectionLayer
 Set objRS3 = objSelLayer3.Records
 objRS3.Bookmark = Map.SelectionBookmark
 Set objEditForm3 = application.map.layers("Supports").forms("EDITFORM")
 Set objEFPageOneControls3 = objEditForm3.Pages("page3").Controls
 ' Populate variables to the form controls.
 Dim varMUTCD_CODE
 varMUTCD_CODE = objEFPageOneControls3("MUTCD_CODE").Value
 Dim objForm, objPageControls, rs
 Set objForm = EDITFORM
 Set objPageControls = objForm.Pages("PAGE3").Controls
 Set rs = CreateAppObject("recordset")
 rs.Open "C:\GPS_data_collections\StreetSign_Collection_ArcPAD\DBF_Lookup_Files\MUTCD_Code.dbf", 2
    'search for the current records MUTCD_Code
    dim dbfQuery, editRecord
    dbfQuery = "[MUTCD_Code] = """ & varMUTCD_CODE & """"
    editRecord = rs.find(dbfQuery)
    'edit the record
    if (editRecord > 0) then
  Dim Answer, MyNote
  MyNote = "Are you sure you want to delete this MUTCD Code?"
  Answer = MsgBox(MyNote, vbQuestion + vbYesNo, "???")
  If Answer = vbNo Then
   Exit Sub
  Else
   rs.movefirst
   rs.move(editRecord - 1)
   rs.Delete
   rs.Update
   rs.Close
  End If
    end if
    set rs = nothing
Tags (3)
NeilChristie
I've had problems with this in the past.  Try removing the double quotes from the rs.Open line.  The stucture that works for me is to store the filepath and name in a variable and reference that in the rs.Open line wrapped in brackets.
Eg.   rs.Open (FileToUseVariable), 2
Hope this helps.
Cheers,
Neil.
JayKappy
This is what I did to no avail....cant figure this one out...driving me nuts...
I know that I am getting into the RS because I can return the correct record with this
Dim varDescription
varDescription = rs.fields("Descriptio").value
msgbox "Value is: " & varDescription
..snip
I thank you all for your help with this...any other thoughts woudl be great but understand this is hard to pin point...
HAVE A GREAT HOLIDAY.
Dim FilePath
FilePath = "C:\GPS_data_collections\Packets_Outgoing\Support_Signs_Data_Collection_2011\MUTCD_Code.dbf"
rs.Open(FilePath),2
Dim dbfQuery
dbfQuery = "MUTCD_Code = """ & varMUTCD_CODE & """"
rs.find(dbfQuery)
Dim varDescription
rs.Delete
rs.Update
rs.Pack
rs.Close
msgbox "Deleteing"
set rs = nothing
..snip
RolfBroch
This is strange, try to use the code below to check if the record is deleted.
Dim varDescription
rs.Delete
rs.Update
MessageBox "Is the record deleted? " & CStr(rs.IsDeleted)
rs.Pack
rs.Close
msgbox "Deleteing"
set rs = nothing
NeilChristie
Try wrapping your field name in square brackets in the query variable.
Without them, the search finds the correct record in the recordset but the delete doesn't happen.
With them, the search finds the record and the recordset is updated after the delete.
Cheers,
Neil.
JayKappy
Dim varDescription
rs.Delete
rs.Update
rs.Pack
rs.Close
msgbox "Deleteing"
set rs = nothing
It tells me FALSE
JayKappy
Cheers,
Neil.
I think the [] worked.....Yea it did....THANK YOU VERY MUCH
