Customize Related Table Forms in ArcPad 10
1401
10-13-2010 07:45 AM
AshleyCassol
I have a feature class (Hydrants) and a related table (Hydrant Inspections). The hydrant inspections table has a lot of Yes/No fields. I am trying to set up radio buttons in ArcPad with related forms, which is going ok. I can get the radio buttons to work in the ArcPad form, however, when I go to the next feature to "complete an inspection" and I get to the Page with the realted form info, the radio buttons are preselected with whatever I filled out for the inspection I just came from. I can change them to reflect the current inspection, however I want them to be "unchecked" or "blank" when I open a "new" form. I can't figure out what code is necessary to do this. I was assuming that I could use something in the "onload" command of either the form or the page in which the radio buttons were present. I can't figure it out! I keep getting errors when I try to test it in ArcPad that says
"vbscript runtime error object required 'name of radio button' text unavailable
Please Help!
Ashlie
Tags (3)
GarethWalters
Hi Ashlie,
Could you describe your data a bit more or put the project up here so we can have a look? What values are your radio buttons storing?
Gareth
SueJohnston
Ashlie,
I've noticed a few different posts from you as I am trying to do the same thing that i think you may have already accomplished.  I am trying to create a custom form to do hydrant inspections.  I've tried to customize the riverside sample, but with no luck.  I was hoping maybe you could provide me some insight?!
Sue
