collecting a point feature for every position
791
05-01-2013 07:24 AM
ScottMarion
Does anyone know of way (other than using the tracklog) to record a stream of points, one for each position at 1-sec intervals in ArcPad? Maybe by scripting? The reason I can't use the tracklog is that I'd like to be able to post-correct the points (using Trimble Positions), and I don't believe I can get Positions to log positions associated with the tracklog to an ssf file, because there is no feature acquisition happening.
Thanks!
Tags (3)
GarethWalters
Hi Scott,
You could either use a script and collect a point when the GPS.OnPosition event fires, or you could use a timer event and be specific about its time.
I hope this helps.
Cheers,
Gareth
