Capture Latitude/Longitude
1209
07-09-2010 05:14 AM
HannahMelton
I am using AddXYZ applet to capture x, y, latitude and longitude fields.  Unfortunately, the applet is putting the x/y data in the latitude/longitude.  IN other words, the latitude and longitude are showing in state plan instead of dms.  My projection file is Florida State PLane.  Does anyone know how I can capture the lat/long in dms?  Thanks!
Tags (3)
StephenQuan
I'm guessing that you have some VBScript / JScript customization skills with ArcPad, if not, it'll be harder to guide you. The rough code outline is:
1. Create a Point object in the current map projection using CreateAppObject
2. Initialize it to your X, Y coordinates
3. Create a Coordinate System object
4. Initialize it to a Geographic Coordinate system (e.g. set it to the WKT string of WGS 1984)
5. Use the Coordinate System's Project method to reproject your coordinates to Geographic coordinates
6. Update the script to use Geographic X, Y for Longitude, Latitude respectively
