Cannot Check in in ArcMap 10.1 with ArcSDE 10.1 Geodatabase
2749
07-18-2012 01:32 AM
geogeekgeogeek
Cannot make Arcpad Check in inside ArcMap 10.1 Against  Postgres ArcSDE 10.1 Geodatabase it gimme the message
"1 out of 1 AXF files were processed.  Here are the results:  * There were no edits in the selected layers in C:\Documents and Settings\Administrateur\Bureau\geo_db3\DataForArcPad4\sde_DEFAULT_192_168_142_129.axf."
despite i have a lot of edits their AXF_status  remains "1" , like it haven't been checked in
while i can make check ins Against a file Geodatabase using the same schema and data.
Any Help plz, to make check in or another solution like using file geodatabase which will be synchronized with SDE geodatabse
Tags (3)
geogeekgeogeek
i have had some related tables value errors in foreign keys , so the check in hadn't been done for data integrity reasons , i have made a data clean up , and it works fine right now 🙂
geogeekgeogeek
