Auto Populate
3121
10-02-2013 09:00 AM
BillHendricks
I am wondering if there is a way to auto populate Lat and Long in the attribute table using arcpad 10.2
Tags (3)
TimWitt
Bill,
this might help you?
Tim
BillHendricks
I have a very basic knowledge of Arcpad. I tried using the applet without success
HannahFerrier
Hi Bill,
Good news!! In ArcPad 10.2 we have introduced QuickFields - which are designed to do exactly what you are after!!
To set up:
  • Create fields in your points layer to store the lat/long data (eg. PointX & PointY)
  • Add data to ArcPad (this will make sure your data is loaded into the QuickFields Expression Builder)
  • Put ArcPad into Design Mode
  • Select the QuickFields tool to launch the Expression Builder and Select ADD to create a new expression
  • Choose the LAYERS option, then select your Layer and Field from the Drop-Down Lists
  • Give your expression a name (this helps you manage multiple rules)
  • Select POINTS as your filter and SHAPE X or SHAPE Y as your function
  • This will add the function to your expression (the blue text at the bottom of the Expression Builder)
  • Select OK and repeat the process for the next field include both X and Y
  • Take ArcPad out of Design Mode select the QuickFields Tool to switch QuickFields ON for your map
  • Now when you collect your points - these fields will auto-populate with the SHAPE X and SHAPE Y data  🙂
See here for more details,
Hannah 🙂
BillHendricks
Thanks Hannah. For some reason only 2 fields are available to edit in quick fields. Id and Latitude even though i have longititude in the attribute table as well
