Auto Increment greyed out in Control Properties
2392
6
10-18-2012 12:09 PM
DanKlenjoski
I am working on a sign inventory application in ArcPad 10. When I create the edit control box for the ID I want, the Auto Increment check box is greyed out. I have tried everything and followed the tutorial for the Tree inventory which implements this but I cannot figure out what i am doing wrong.
All sign data I am using for the project resides in ArcSDE 10.1
Any help would be appreciated.
Dan
Tags (3)
ThaiTruong
I think I know what is going on here....
The Auto Increment feature only works with shapefiles.  So, if you use *.axf, then you're out of luck! 🙂
If you don't want to use shapefiles, then you need to write some VBA to help you maintain your IDs.
ThaiTruong
I used to have a project created with ArcPad 7/8, and the auto Increment function didn't work for me back in that time.  I end up created a custom function to help me manage the auto increment IDs and called it when my user created a new feature.
Anyways, making sure that the field is a numeric boundfield.  I hope that the option enabled if the field is a numeric type.
ThaiTruong
DanKlenjoski
Ah, that makes sense now. Thanks for the quick response. Do you have any examples of how to write a VBA to maintain my ID's? I am green in the VBA arena.
Thanks.
GustavoBediaga
Take a look at the Login Form Script
http://arcscripts.esri.com/details.asp?dbid=16477
or the Auto Increment Script
http://arcscripts.esri.com/details.asp?dbid=10160
Hope it helps you.
Gustavo
DeniseKing
You may also want to look at a recent blog topic on ArcPad Team Blog - Incrementing ID's.
Cheers,
Denise
DanKlenjoski
Thanks for the help/links!
