ArcPad v10.02 Altitude Display
1154
05-06-2011 09:36 AM
LisFano
The Altitude (meters) and Altitude (feet) display in the GPS>Data tab, and also on the main screen, is displaying an output like 1.5e+003m. The depth display options appear correctly. Is anyone else having this problem? - Using Trimble Juno SB, GPScorrect v.3.16
~Lis
Tags (3)
AlexMahrou
What are your display units set to under "options", "display" in ArcPad? Also, make sure that your under your GPS Preferences, that your antenna height is correct, your geoid separation is set to zero, and you have a check by "use map map units for height units & it says meters".
LisFano
Thank you for the input Alex. I double-checked all of my preferences, even tried switching from metric to standard for good measure, but still can't get the altitude to display correctly. I ended up rerverting back to v10.0, with no problems since the unit hit the field today.
Cheers,
~Lis
