ArcPad Select Method
1088
06-07-2012 11:10 PM
JamesNunn
Hi
I'm trying to create a tool which will select a feature (point) by using a bookmark which has been previously set in another tool.
From the Developer Help:
object.Select ( Layer [,Bookmark] )
Doing:
Map.Select ("Buildings", Application.UserProperties("bdgbookmark"))
results in an error for using parentheses in a sub.
Map.Select "Buildings", Application.UserProperties("bdgbookmark")
just tells me there is a type mismatch.
What am I missing?
Tags (3)
ThaiTruong
Hi James,
have you tried to print Application.UserProperties("bdgbookmark") to see what value is returned?!
SuzanneAngelo
I had this same problem today.  Apparently ArcPad is expecting a Layer object, not just a string.  So, for the example above...
Map.Select Map.Layers("Buildings"), Application.UserProperties("bdgbookmark")
(Assuming that that UserProperty is of type Long.)
