ArcPad relationships between spatial tables and non-spatial tables
1327
05-25-2012 12:07 AM
JamesNunn
Hi
I currently have 3 tables in a GDB which each have a relationship (1-M) with each other. 2 of them are point feature classes and one is a table with no spatial data. Using Identify on either of the points in Arcmap behaves as expected, showing me the related records within the two other tables.
After checking out the data using the ArcPad toolbar, I load the data into ArcPad and use the Identify tool on either of the points . This result in the form shows me only the related record within the non-spatial table, and appears to ignore the relationship with the other points table. Is this the intended behaviour of am I missing something?
James
Tags (3)
TimHopper
James,
This is expected behavior.  Feature class to feature class relationships are not supported.
Take a look at the Preparing your data for ArcPad help topic, which discusses data formats which are not supported by the ArcPad Data Manager.
[ATTACH=CONFIG]14646[/ATTACH]
TimHopper
James,
JamesNunn
Thank you, for some reason it is hard to find explicit information like this in searches.
