ArcPad no data imagery filter
1595
11-13-2017 01:00 PM
IngridHogle
Is there a way to stop ArcPad from displaying areas of No Data (0 in my case) within a .tif image as solid black? I'm using LZW compressed, orthorectified .tif images (high resolution 2008 USGS orthoimagery).
I have clipped our imagery to our project area. The resulting images are not rectangular, and the parts of the maximum extent rectangle that do not contain imagery show up as solid black fill within ArcPad. (These areas are null/transparent when viewed in ArcMap.)
IngridHogle
I had no idea I could do this. Wow! So simple! Thank you so much.
StephenQuan1
Sorry Ingrid, ArcPad only supports alpha channel supplied in an additional band. For instance, RGBA. If you can create the alpha channel band. A 32-bit TIFF image containing 8-bit for each channel and the last with the Alpha channel will have the following TIFF tags set:
  • TIFF Tag 258 Bits Per Sample (e.g. 😎
  • TIFF Tag 262 Photometric Interpretation (e.g. PHOTOMETRIC_RGB = 2)
  • TIFF Tag 338 Extra Samples (e.g. 1)
MarikaVertzonis
Have you tried setting the transparency on the image in its layer properties? Go to:
Table of Contents > Select the layer > Layer properties > Transparency. The default is no transparency, change this to black. Click OK. You should see the black parts of the image disappear. See ArcPad Help for more info.
IngridHogle
