ArcPad GPS
3537
08-24-2011 12:49 PM
BrianTorborg
We are currently running ArcPad 8.0 on a Panasonic Toughbook CF-19 equipped with the default GPS unit on the Toughbook itself.  We do a lot of our work in a vehicle so we are looking to purchase an external mag mount Trimble unit to increase reception and accuracy.  Does ArcPad have the ability to switch back and fourth between different GPS antennas/recievers so when we go outside of the vehicle, we would be able to switch back to the default GPS receiver?  Does anyone know of any major issues with any specific GPS receivers?
Thanks for the help!
Tags (3)
JohnLucas
Brian
we run multiple GPS units with our Rugged tablet computers with no trouble.
It is not a big deal to change units. you simply change the port number and Baud in GPS preferences. (the pull down menu under the satellite icon). To speed things up you can configure the external Trimble GPS with the same baud rate as the internal GPS.  beware if the Baud rate is 4800 as the computer may think the external GPS is a mouse and the cursor will jump all over the screen.  If this occurs then you must disable the serial mouse in the device manager.
also you will need some sort of differential service WAAS, OMNISTAR etc on the external Trimble unit other wise the accuracy gain will be marginal if at all.
Hope this helps,
JL
