ArcPad Data Manager is greyed out in ArcMap???
5182
6
08-16-2010 10:09 AM
JohnAllen
I added to ArcPad Data Manager to Arcmap to check in and check out data and the selectable features are greyed out in ArcMap. What am I doing wrong?
Tags (3)
EricHajek1
Is the extension turned on?
JohnAllen
I suppose? I just right clicked and added ArcPad Data Manager to my ArcMap tool bars and its greyed out. I can't select any of its features.
As far as being turned on I'm not sure. Suggestions?
JohnZimmerman
I had the same problem.  You have to turn on the extension; I cannot remember which menu did it but you will find it.
Unfortunately, you may find like a lot of us that the Data Manager does not work and crashes ArcMap but good luck.
JohnAllen
I figured out how to fix the "ArcPad Data Manager is greyed out in ArcMap". You have to turn the extension on...of course! haha.
To do this:
1. Open Arcmap 10
2. Right Click in toolbar area and select Arcpad Data Manager.
3. At this point the Arcpad Data Manager icons are greyed out.
4. Select "Customize" - "Extensions"
5. Check ArcPad Data Manager
6. Close
This process should allow you to be able to select the icons in ArcPad Data Manager.
JohnAllen
John Zimmerman,
You are right. Every-time I try to check out data through ArcPad Data Manager, ArcMap 10 crashes and I am unable to check out my data.
I just called ESRI tech support and they said they would call me back some time today. If I get an answer I will post it on here.
Just for reference purposes. I'm running.
ArcMap10
Checking out data from SDE Geodatabase (Versioned)
HP Desktop PC
Windows XP Professional
Service Pack 3
3.5 GB of RAM
Quad-Core Processor
Juno SC
Windows Mobile 6.1 Classic
ArcPad 10
JohnAllen
I figured out why ArcPad Data Manager extension was crashing ArcMap 10.
See Thread: ArcPad Data Manager shuts down ArcMap
