ArcPad Data Manager 9.2 Check In Issue
1445
05-24-2010 06:24 AM
StevenRehbaum
I am running tests on some Utilities data.  Each layer has a few subtypes and many domains.  I am successful in creating the .axf for ArcPad 8 and it seems to work just fine.  When I try to check-in the data, the ArcPad Data Manager will show me which layers have changes, but it hangs for a while (60+ minutes) and ultimately fails to import the data (on my local PC).  No changes are made to the source .GDB schema while the data is checked-out.  I have 30 layers I would like to be checked in and out, but not all layers will be edited all the time.  I am wondering if the complexity of the subtypes and domains are bogging down the system.  Anyone have an experience like this and/or a solution besides reinstalling ArcPad (if that would even work in this instance)?
Tags (3)
StevenRehbaum
Apparently the .APX is very sensitive.  I ran a repair on Arcpad 8 and created another. APX and it worked fine.  I am wondering if any of you have experienced issues as a result of highly complex subtypes and domains.  I have 30 layers that all have subtypes and at least 6 domains each.  Is there some kind of threshold for the .APX?  I am thinking about possibly removing the subtypes and just carrying the variable as an attribute only in order to eliminate a small part of the overall complexity of the layers.
StephenQuan
Having a large layer and subtype count did influence performance in ArcPad 8. A number of those issues were dealt with in ArcGIS 10 / ArcPad 10.
Are you able get hold of the latest versions of these products and retry your scenario?
BryceSmith
ArcPad Data Manager is not supported on ArcGIS 9.2, so is not surprise that you cannot check data back in.
Cheers
Bryce
StevenRehbaum
Cheers
Bryce
Had same issue with 9.3, but I am moving towards an .axf out of ArcSDE.  I am in the process of removing unnecessary domains to shrink the overall .axf size.  Having tested it successfully already from a local .gdb, I am looking forward to no more DB bloat.
