Arcpad Checkout
3260
06-26-2015 11:47 AM
BrianCoolidge
We have an arcpad axf file that was checked out from a database on our local server.  While the data was checked out, we had a server migration and now that old server does not exist.  While we have the data on a new server (with a new name), Arcpad is trying to force us to check it back into the server name that does not exist and we cannot change the path.
Is there anyway to check this data back into our geodatabase in the new location?
HannahFerrier
Brian,
ArcPad will only check data back into the geodatabase it came from. However, if you have data in an .axf file that is unable to bve checked in, you could extract this data using FME. This will allow you to convert an .axf file into a geodatabase, and migrate the data manually into your new geodatabase location. See here for more information: http://support.esri.com/es/knowledgebase/techarticles/detail/39505
Hannah
