ArcPad Check out FAILS if I use OS authentication connecting database and version data
866
08-19-2016 05:42 AM
DiegoLlamas
I am collecting some data using a GPS and ArcPad. I use a version layer and OS authentication to connecting database. I notice after I upgrade to ArcPad 10.2 I was not able to do a check out using version data and an OS connection.
If I use an OS Connection and select a version I cannot create a check out
If I use an OS Connection and select default version I can create a check out but not able to do Check in to default
If I use Data Base connection and Version I am able to do check out.
My scenario should be Version data and OS Connection but i am not able to get to the las gray window "successful Finish" after following check out wizard.
it is possible to have this scenario, right?
Do you know if there is some kind of bug with ArcPad 10.2 for this scenario
as a workaround i am using database authentication.
Thanks for your help!
Diego Llamas
