Arcpad 9.x .apm will not open in Arcpad 10.x
3625
02-03-2012 04:58 AM
DanielHofer
I demoed this arcpad project and the files I'm trying to open on a laptop and netbook using arcpad 9.x.  This arcpad was developed for another state.  Everyone liked it.  So we bought the latest Arcpad 10x.  I thought I'd just edit all the data from the other state to our state so we can rinse and repeat.
However, I cannot open the .apm file using Arcpad 10.x.  Arcpad just opens blanks with clickable tools but nothing to do.
I had a guy in another state test the files on his machine running arcpad 7.x and everthing worked fine.
The .apm file is zipped and attached.
Any ideas.
Tags (3)
BrettBlack1
Daniel,
Are you using ArcPad Data Manager in ArcGIS Desktop to check-out data and create the APM? If not, I would recommend utilizing it. Once the check-out is completed it will provide you with the APM file as well as AXF files or SHP files depending on what you selected. These AXF files contain the features, fields, etc. to be viewed and edited in the field. An APM file without the AXF files is kind of like a MXD without a geodatabase or shapefiles within it.
I hope this helps.
HannahFerrier
The ArcPad Map Document (.apm) only contains references to your datasets (just like ArcMap). To view your data through the map document - you must have the correct references to your datasets.
If you open your .apm file in Notepad, you will see that the layers are referencing a file path that begins with 'SD Card'. If you are now running this project on a laptop - this may not be where your datasets reside on that machine (hence the empty map).
You can always begin with a new map and add the shapefile layers one by one to ensure correct reference paths.
Also - there was no ArcPad version 9 - it jumped from 8 to 10 (I like to think that this is because ArcPad seven ate (eight) nine!!)
DanielHofer
Excellent!  It was changing the file path using notepad.  I can now view that apm.  What a relief.
Now I need to keep the forms and change everything that is Wyoming to Colorado.  I will use the ArcPad Data Manager to finesse this.  Please keep an eye on this thread in case I get stuck.  Thank you both.
