ArcPad 7.1 & ArcGIS Server 10
1395
03-20-2012 04:12 AM
AndrewMilanes
Can ArcPad 7.1 connect to services on an ArcGIS Server 10?
I have a Magellan MobileMapper CX that cannot upgrade past ArcPad 7.1.
Tags (3)
KevinBurke
In order to be able to utilize services from ArcGIS Server in ArcPad, you would need the ArcGIS Server ArcPad Extension. However, that extension was first released for ArcPad 8. Therefore, if you are using ArcGIS Server 9.3, you will require the ArcGIS Server ArcPad 8 Extension. If you are using ArcGIS Server 10, you will require the ArcGIS Server ArcPad 10 Extension.
So in order to be able to consume services in ArcPad and because you are running ArcGIS Server 10, you would need the ArcGIS Server ArcPad 10 Extension. Therefore ArcPad 7.1 would need to be upgraded to version 10.
http://arcpadteam.blogspot.com/2010/07/arcpad-10-compatibility-with-arcgis-93.html
Thank you.
AndrewMilanes
Well that stinks.  According to Magellan, the MobileMapper CX will not run ArcPad newer than 7.1.  Just my luck.
