ArcPad 10 - QuickProject Default Folder Location & Name
1382
09-14-2010 04:54 PM
PhilDrummond
Sure it's easy enough to amend the 'Default Maps & Data Path' but can you change the default QuickProject folder naming convention from "QuickProject YYYY-MM-DD HHNNSS" to something else?
As suggestion may be to use the name of the template selected when running the QuickProject wizard instead (eg: "Fire Perimeter YYYY-MM-DD HHNNSS") or allow the user to select the location (similar to the GPS Tracklog Filename properties)
Tags (3)
GregoryLewis
I am looking at the same thing, I assume you didn't get an answer for this?
-Greg-
DeniseKing
This thread is a great example of topics better suited for the ArcGIS Ideas > Mobile GIS category.  ArcGIS Ideas site is where users can submit and vote on ideas submitted by user community. Please remember to tag your ArcPad Idea with appropriate keywords including "arcpad" for easier searching of all ArcPad Ideas.
Cheers,
Denise
