ArcPad 10 ArcPad Data Manager - Can't check in data
2730
03-28-2011 03:55 PM
WillAnderson2
Hi:
I'm having a problem checking data into a File GDB using ArcGIS 10 ArcPad Data Manager.  I have point, line, and polygon feature classes in the same file geodatabase that I move to a mobile device using the 'Get Data For ArcPad' option with the ArcPad Data Manager.  It doesn't matter whether I export data as editable shp files, an editable axf file, or through Check Out - I get an error about missing a time stamp when I try to move the data back in.  I'm not running in a versioned environment, just one PC with data in a file geodatabase.  Help!
Cheers,
Will
Tags (3)
JasonTipton
Try reinstalling ArcPad???
1st open the .axf with ArcPad Studio. Right click the feature layer. Show Data. Is the AXF_Status really null? It shouldn't be whenever the AXF_status is not null.
If this is the case, I would assume that it is ArcPad. Try reinstalling it?
And you can still right click, export data as shapefile.
WillLentz
Is the time, date and time zone set correctly on your device?
Will
