Adding raster resets Datum in Map Properties
915
05-17-2012 10:34 AM
JasonWeis
I am running ArcPad 10.0 R3 (Build 33) on a Windows 7 (64-bit) desktop.  The problem can be replicated on a Trimble Yuma (Windows 7 32-bit).
I have exported several ArcPad projects from ArcGIS 10.  In all of the projects, all of the data uses the "NAD_1983_HARN_WISCRS_Outagamie_County_Feet" projected coordinate system.  After creating the ArcPad APM, the "Projection" tab in the Map Properties shows a projection of "NAD_1983_HARN_WISCRS_Outagamie_County_Feet" and a Datum of "D_North_American_1983_HARN(6152)", as would be expected.  I am able to edit the APM file (toggle layer visibility, symbology, etc.) and save the APM with no difficulties.  When I reopen the file, everything in the Map Properites Projection appears normal.
However, if I manually add an orthophoto layer to the APM (which is also defined to have the "NAD_1983_HARN_WISCRS_Outagamie_County_Feet" projection) and save the APM file, the Map Properties Datum is reset the next time I open the APM.  The Projection still reads "NAD_1983_HARN_WISCRS_Outagamie_County_Feet", but the Datum now reads "NAD83_High_Accuracy_Regional_Network (0)".
This causes an issue when operating on a unit with a GPS, as I receive the warning "No datum transform from D_ITRF_2000 [or D_WGS_1984] to NAD83_High_Accuracy_Regional_Network."  No warning is received before the Datum is reset, since there is a tranform between D_ITRF_2000 and the original Outagamie County projection.
One potential work-around is to make sure the user does not save the APM after adding the raster image, but this would require manually adding the raster layer each time the APM is opened (and remembering not to save the APM during the session).  Has anyone else noticed this, and possibly found a solution?
Tags (3)
HannahFerrier
Hi Jason,
Could you attach a copy of your .apm and raster layer so that we can have a go at reproducing this behavior??
My initial thoughts would be to check and double-check the projection information in the header of your raster. You may need to use a program like IrfanView to do this...
Another option you may want to try in the meantime would be to add the layer to your map then use 'Save As' to save a new .apm
Open the new and original .apm files in Notepad and copy the layer reference for your raster from the new .apm and paste that into your original .apm
This should ensure that the datum information is not changed in your .apm but your raster has been included.
Let me know how you get on,
Hannah
