Zooming to a parcel when selecting a row in the dataGridView C#.net
3393
12-27-2010 07:42 PM
MustaphaKoaik
hello,
iam selecting some parcels through an out-of the -box tool then displaying the selected feature(Parcels) with its attributes in a dataGV,i then want to select a specific row then zoom to the selected parcel( which is a row in this case) can any body help.
thnx in advance.
Venkata_RaoTammineni
hello,
thnx in advance.
Dim sWhereclause As String
    sWhereclause = ""
    QueryDef pLayer, sWhereclause
    Dim pFeatureSelection As IFeatureSelection
    Set pFeatureSelection = pLayer
    Dim pQueryFilter As IQueryFilter
    Set pQueryFilter = New QueryFilter
    pQueryFilter.WhereClause = sWhereclause
    pFeatureSelection.SelectFeatures pQueryFilter, esriSelectionResultNew, False
    Application.Document.CommandBars.Find(arcid.Query_ZoomToSelected).Execute
convert above code into C# and .. what you do is ...get selected item from gridview... and send into whereclause...
MustaphaKoaik
thank you vakant for your help..i worked with this code before you posted and it worked pretty well
        protected void GridView2_SelectedIndexChanged(object sender, EventArgs e)
            IMapFunctionality mf =
           Map1.GetFunctionality("Redlands") as IMapFunctionality;
            IGISResource gisresource = mf.Resource;
            string targetLayername = "Parcels";
            // Create the query functionality
            IQueryFunctionality qfunc =
                gisresource.CreateFunctionality(typeof(IQueryFunctionality), null)
                   as IQueryFunctionality;
            string[] lids;
            string[] lnames;
            qfunc.GetQueryableLayers(null, out lids, out lnames);
            int layer_index = 0;
            for (int i = 0; i < lnames.Length; i++)
                if (lnames.ToLower() == targetLayername.ToLower())
                    layer_index = i;
                    break;
            // Create the spatial filter for the query
            ESRI.ArcGIS.ADF.Web.SpatialFilter spatialfilter = new ESRI.ArcGIS.ADF.Web.SpatialFilter();
            spatialfilter.ReturnADFGeometries = true;
            spatialfilter.MaxRecords = 1000;
            spatialfilter.WhereClause = "OBJECTID= " + GridView2.SelectedRow.Cells[1].Text;
            spatialfilter.Geometry = Page.Session["Envelope"] as Envelope;
            String[] flds = qfunc.GetFields(null, lids[layer_index]);
            ESRI.ArcGIS.ADF.StringCollection scoll =
                new ESRI.ArcGIS.ADF.StringCollection(flds);
            spatialfilter.SubFields = scoll;
            DataTable dt;
            dt = qfunc.Query(null, lids[layer_index], spatialfilter);
            // *** Step 7.d.: Convert the data table returned from the query
            // *** and define symbology.
            GraphicsLayer resultsGraphicsLayer;
            resultsGraphicsLayer = ESRI.ArcGIS.ADF.Web.Converter.ToGraphicsLayer(dt, System.Drawing.Color.Red, System.Drawing.Color.Purple);
            Map1.Extent = resultsGraphicsLayer.FullExtent;
            // Apply a layer format to specify:
            // * how selected features appear
            // * field aliases
            // * visible fields
            // * primary display field
            // * attribute formatting
            // Retrieve the layer format for the active layer.
            ESRI.ArcGIS.ADF.Web.UI.WebControls.LayerFormat layerFormat =
                ESRI.ArcGIS.ADF.Web.UI.WebControls.LayerFormat.FromMapResourceManager(
              Map1.MapResourceManagerInstance, mf.Resource.Name, lids[layer_index]);
            // *** Step 7.e.: Apply the layer format of the active layer
            // *** to the feature graphics layer.
            layerFormat.Apply(resultsGraphicsLayer, true);
            ESRI.ArcGIS.ADF.Web.DataSources.Graphics.MapFunctionality graphicsFunctionality;
            graphicsFunctionality = (ESRI.ArcGIS.ADF.Web.DataSources.Graphics.MapFunctionality)Map1.GetFunctionality("Selection");
            // If RenderOnClient is true, the Web-tier graphics layer will be rendered on the client using the
            // Web ADF JavaScript Library (GraphicFeatureGroup and GraphicFeatures).
            // The default and highlight renderer defined as part of the active layer's layer format will be used during
            // mouse over events on graphic features.  Field and attribute display styles will be used to define the format of
            // map tip (callout) content.  If false, it will be rendered as a map image in the Web-tier using GDI+ and
            // consolidated with other resource map images in the browser.  Only layer format's default renderer will be used
            // to render features -  map tips will not be generated and the highlight renderer will not be used.
            resultsGraphicsLayer.RenderOnClient = false;
            if (resultsGraphicsLayer.RenderOnClient)
                // Use ADF JavaScript to change active tool in toolbar and map control on client.
                // This is optional.
                // The mouse mode is set to Pan after Web-tier graphics are rendered on the client.
                // This enables you to interact with map tips on graphic features without erroneously defining a new selection.
                // NOTE: You need to activate the select tool to make another selection.
                string jsToolbarItemDeactivate = @"
                var toolbar = Toolbars['{0}'];
                var currentToolField = $get(toolbar.currentToolField);
                currentToolField.value = '';
                toolbar.selectTool();
                toolbar.refreshGroup();
                $find('{1}').set_mouseMode(ESRI.ADF.UI.MouseMode.Pan);";
                Toolbar adfToolbar = (Toolbar)Map1.Page.FindControl("Toolbar1");
                adfToolbar.CurrentTool = string.Empty;
                Map1.CurrentToolItem = null;
                jsToolbarItemDeactivate = string.Format(jsToolbarItemDeactivate,
                    adfToolbar.ClientID, Map1.ClientID);
                ESRI.ArcGIS.ADF.Web.UI.WebControls.CallbackResult deactivateToolbarItemsCallbackResult =
                    ESRI.ArcGIS.ADF.Web.UI.WebControls.CallbackResult.CreateJavaScript(jsToolbarItemDeactivate);
                Map1.CallbackResults.Add(deactivateToolbarItemsCallbackResult);
                // Remove the current graphics feature group associated with the last selection.  This will guarantee that the
                // new graphics, attributes, and behaviors will be used.  As a result, only one graphic feature group will reside
                // in the client to represent the selection set.
                if (graphicsFunctionality.GraphicsDataSet.Tables.Count > 0)
                    ESRI.ArcGIS.ADF.Web.Display.Graphics.GraphicsLayer oldFeatureGraphicsLayer =
                        (ESRI.ArcGIS.ADF.Web.Display.Graphics.GraphicsLayer)graphicsFunctionality.GraphicsDataSet.Tables[0];
                    // Use the Map.GetGraphicsLayerClientID to get the id of the respective graphic feature group that represents
                    // the Web-tier graphics layer.
                    string removeGraphicsClientScript = string.Format(@"
                var glayer = $find('{0}');
                var map = $find('{1}');
          map.removeGraphic(glayer);
          glayer.dispose();",
                          Map1.GetGraphicsLayerClientID(oldFeatureGraphicsLayer),
                          Map1.ClientID);
                    ESRI.ArcGIS.ADF.Web.UI.WebControls.CallbackResult cr =
                        ESRI.ArcGIS.ADF.Web.UI.WebControls.CallbackResult.CreateJavaScript(removeGraphicsClientScript);
                    Map1.CallbackResults.Add(cr);
            // Clear all contents of the graphic map functionality dataset
            graphicsFunctionality.GraphicsDataSet.Tables.Clear();
            // *** Step 7.g.: Add the selection graphics layer to the resource
            graphicsFunctionality.GraphicsDataSet.Tables.Add(dt);
            // Set the transparency of the selection graphics resource map resource item
            ESRI.ArcGIS.ADF.Web.UI.WebControls.MapResourceItem selectionMapResourceItem =
                Map1.MapResourceManagerInstance.ResourceItems.Find(graphicsFunctionality.Resource.Name);
            selectionMapResourceItem.DisplaySettings.Transparency = 50;
            // *** Step 7.h.: Refresh the map resource
            Map1.RefreshResource(graphicsFunctionality.Resource.Name);
            Toc adfToc = Map1.Page.FindControl("Toc1") as Toc;
            adfToc.Refresh();
            string[] lids;
            string[] lnames;
                    layer_index = i;
                    break;
            DataTable dt;
            // * field aliases
            // * visible fields
          glayer.dispose();",
                          Map1.ClientID);
            adfToc.Refresh();
good work congrates...
