Zoom to selected features
4167
10
06-01-2010 12:26 AM
NehayaArabeiat
Hi Everybody,
I build an ArcGIS Engine Application in vb.net language, I want to select a field in a feature layer and zoom to it, I try the following code but when I click the button it zooms to nothing and the map disappear, any help please??
Shared Sub SelectLayersFeatures(ByVal pFeatureLayer As IFeatureLayer, ByVal WhereClause As String, ByVal pActiveview As IActiveView, ByVal blockclass As IFeatureClass)
        Dim pFeatureSelection As IFeatureSelection = pFeatureLayer
        Dim pfeaturezoomlayer As IFeatureLayer
        If Not pFeatureSelection Is Nothing Then
            Dim pQueryFilter As IQueryFilter = New QueryFilterClass()
            pQueryFilter.WhereClause = WhereClause
            pFeatureSelection.SelectFeatures(pQueryFilter, esriSelectionResultEnum.esriSelectionResultNew, False)
            pActiveview.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, Nothing, Nothing)
            pfeaturezoomlayer = pFeatureSelection
            pfeaturezoomlayer.FeatureClass = BlockClass
            Dim pFSel As IFeatureSelection
            pFSel = pFeatureLayer
            Dim pSelSet As ISelectionSet
            pSelSet = pFSel.SelectionSet
            Dim pEnumGeom As IEnumGeometry
            Dim pEnumGeomBind As IEnumGeometryBind
            pEnumGeom = New EnumFeatureGeometry
            pEnumGeomBind = pEnumGeom
            pEnumGeomBind.BindGeometrySource(Nothing, pSelSet)
            Dim pGeomFactory As IGeometryFactory
            pGeomFactory = New GeometryEnvironment
            Dim pGeom As IGeometry
            pGeom = pGeomFactory.CreateGeometryFromEnumerator(pEnumGeom)
            pActiveview.Extent = pGeom.Envelope
        End If
    End Sub
    Private Sub Button4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button4.Click
        Dim where As String
        where = "GeoCode2 = '" & Blocks_List.SelectedItem & "'"
        Dim pfeaturelayer As IFeatureLayer
        pfeaturelayer = New FeatureLayer
        pfeaturelayer.FeatureClass = BlockClass
        ' Dim blockclass2 As IFeatureClass
        Dim pActiveview As IActiveView = AxPageLayoutControl1.ActiveView
        'blockclass2 = pFeatureworkspace.OpenFeatureClass("Jerash_Blocks")
        'pfeaturelayer.FeatureClass = blockclass2
        SelectLayersFeatures(pfeaturelayer, where, pActiveview, BlockClass)
        '  AxMapControl1.ActiveView.Extent = pGeom.Envelope
        AxPageLayoutControl1.Refresh()
        AxMapControl1.Refresh()
    End Sub
PrahladYeri
Just before refreshing the map, when you set the Extent property of the Active View, try doing one more thing.
Try to set the map scale using the Map object in your code.
AxMapControl.FocusMap.MapScale = 1250
I'm not using an ActiveX control, but directly control the ArcMap application through an iCommand. Hence, I get the above variable using _EsriDocument.FocusMap.MapScale where _EsriDocument is a variable of iMxDocument.
If this does'nt solve the problem, let me know. We'll have to try something else.
Cheers,
Prahlad
NehayaArabeiat
Hi prahlad1981,
Thanks for your reply
I have made some changes in the code that I wrote procedure for select features and another one for the zoom then I try your suggestion but the following error appeared:
this is the code:
Public Sub SelectFeatures()
        Try
            pActiveview = AxPageLayoutControl1.ActiveView
            Dim pMap, pmap2 As IMap
            pmap2 = pActiveview.FocusMap
            pMap = AxTOCControl1.ActiveView.FocusMap
            pmap2.ClearSelection()
            pActiveview.Refresh()
            If Not TypeOf pMap.Layer(0) Is IFeatureLayer Then Exit Sub
            pfeaturelayer = pMap.Layer(0)
            pFeatureSelection = pfeaturelayer 'QI
            Dim where As String
                pQueryFilter.WhereClause = where
                AxPageLayoutControl1.ActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, Nothing, Nothing)
            End If
        Catch ex As Exception
            MsgBox(ex.Message)
        End Try
    End Sub
    Public Sub ZoomToSelectedFeatures()
        Dim pMap As IMap
        pMap = pActiveview.FocusMap
        pFSel = pMap.FeatureSelection()
        AxMapControl1.ActiveView.FocusMap.MapScale = 1250
        AxPageLayoutControl1.ActiveView.FocusMap.MapScale = 1250
    End Sub
    Private Sub Blocks_List_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Blocks_List.SelectedIndexChanged
        SelectFeatures()
    End Sub
    Private Sub Button5_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button5.Click
        Try
            MsgBox(ex.Message)
        End Try
    End Sub
PrahladYeri
Hi prahlad1981,
this is the code:
        Try
            Dim where As String
            End If
            MsgBox(ex.Message)
        End Try
    End Sub
        Dim pMap As IMap
    End Sub
        SelectFeatures()
    End Sub
        Try
            MsgBox(ex.Message)
        End Try
    End Sub
Hi Nehaya,
On which line in code is this error occuring?
If it occurs while casting into IFeatureSelection (pFSel = pMap.FeatureSelection()), then try your previous approach if it works for you.
Cheers,
Prahlad.
NehayaArabeiat
Hi prahlad1981,
Yes the error appeared in this line so I tried my previous code but it zoomed to nothing and the map control became blank !!!
Here's my final code:
Private Sub Button6_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button6.Click
        Try
            pfeatureLayer = pMap.Layer(0)
            pfeatureselection = pfeatureLayer 'QI
            Dim where As String
            If Not pfeatureselection Is Nothing Then
                pfeatureselection.SelectFeatures(pQueryFilter, esriSelectionResultEnum.esriSelectionResultNew, False)
                pSelSet = pfeatureselection.SelectionSet
                AxPageLayoutControl1.ActiveView.Extent = pGeom.Envelope
                AxPageLayoutControl1.ActiveView.Refresh()
            End If
            MsgBox(ex.Message)
        End Try
    End Sub
Thank you very much
PrahladYeri
Hi prahlad1981,
        Try
            Dim where As String
            End If
            MsgBox(ex.Message)
        End Try
    End Sub
Thank you very much
Hi Nehaya,
Now that you've set the FeatureSelection object using a different approach (SelectFeatures() func.), has it solved the error ?
Cheers,
Prahlad.
NehayaArabeiat
Hi prahlad1981,
I tried it but the same problem, what can I do??
Thanks for your assistance
JamesCrandall
Hi prahlad1981,
It looks like you have a typo in "esr iViewDrawPhase".  Also, in my implementation (an ICommand .dll which works for ArcMap) I am using esriViewGeography instead.  You can try this by replacing,
AxPageLayoutControl1.ActiveView.PartialRefresh(esr iViewDrawPhase.esriViewGeoSelection, Nothing, Nothing)
with,
AxPageLayoutControl1.ActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeography, Nothing, Nothing)
NehayaArabeiat
Hi jamesfreddyc,
Thanks for your reply...
I tried your solution but the same problem appeared, what's now???
dlldelhi
I found its solution from esri site only, some times back...
I was using ArcMap 9.3, I was having selected FID of feature...then tried this and it worked
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Try
            Dim str
            Dim pFeatureLayerLayer As IFeatureLayer
            Dim pActiveView As IActiveView
            pActiveView = pMap
            pQueryFilter = New QueryFilter
            pFeatureSelection = pFeatureLayer
            str = "FID" & " = " & ComboBox2.SelectedIndex
            pQueryFilter.WhereClause = str
            'Invalidate only the selection cache
            'Flag the original selection
            pActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, Nothing, Nothing)
            'Perform the selection
            'Flag the new selection
            ZoomToSelected(2, True) 'modify last two arguments here to change zoom expansion
            MsgBox(ex.Message, MsgBoxStyle.Exclamation, "ERROR")
            Exit Sub
        End Try
    End Sub
    Public Sub ZoomToSelected(ByVal expandFactor As Double, ByVal bAsRatio As Boolean)
        Dim pDoc As IMxDocument
        pDoc = pMxDoc
        Dim pEnumFeat As IEnumFeature
        pEnumFeat = pDoc.FocusMap.FeatureSelection
        Dim pEnv As IEnvelope
        pEnumFeat.Reset()
        Dim pFeat As IFeature
        pFeat = pEnumFeat.Next
        Do Until pFeat Is Nothing
            If pEnv Is Nothing Then
                pEnv = pFeat.Shape.Envelope
            Else
                pEnv.Union(pFeat.Shape.Envelope)
            End If
        Loop
            MsgBox("no selection")
            Exit Sub
        End If
        pActiveView = pDoc.ActiveView
        Dim pCP As IPoint
        If pEnv.Width <> 0 Or pEnv.Height <> 0 Then
            pEnv.Expand(expandFactor, expandFactor, bAsRatio)
            pActiveView.Extent = pEnv
        Else
            ' if it's a point, leave current extent size, and just center on it
            ' you can do something else here if you want
            pCP = New Point
            pCP.PutCoords(0.5 * (pEnv.XMax + pEnv.XMin), 0.5 * (pEnv.YMax + pEnv.YMin))
            pEnv = pActiveView.Extent
            pEnv.CenterAt(pCP)
        End If
        pActiveView.Refresh()
    End Sub
