Zoom to selected features
1776
06-07-2010 12:21 AM
NehayaArabeiat
Hi All,
I try this code to zoom to selected features but it zooms to nothing and the map becomes blank, what is the problem, please help me??
Private Sub Button6_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button6.Click
        Try
            pActiveview = AxPageLayoutControl1.ActiveView
            Dim pMap, pmap2 As IMap
            pmap2 = pActiveview.FocusMap
            pMap = AxTOCControl1.ActiveView.FocusMap
            pmap2.ClearSelection()
            pActiveview.Refresh()
            If Not TypeOf pMap.Layer(0) Is IFeatureLayer Then Exit Sub
            pfeatureLayer = pMap.Layer(0)
            pfeatureselection = pfeatureLayer 'QI
            Dim where As String
            ' where = "GeoCode2 = '" & Blocks_List.SelectedItem & "'"
            If Not pfeatureselection Is Nothing Then
                Dim pQueryFilter As IQueryFilter = New QueryFilterClass()
                pQueryFilter.WhereClause = where
                pfeatureselection.SelectFeatures(pQueryFilter, esriSelectionResultEnum.esriSelectionResultNew, False)
                ' Dim pfeaturelayer2 As IFeatureLayer
                ' pfeaturelayer2 = pfeatureselection
                Dim pSelSet As ISelectionSet
                pSelSet = pfeatureselection.SelectionSet
                Dim pEnumGeom As IEnumGeometry
                Dim pEnumGeomBind As IEnumGeometryBind
                pEnumGeom = New EnumFeatureGeometry
                pEnumGeomBind = pEnumGeom
                pEnumGeomBind.BindGeometrySource(Nothing, pSelSet)
                Dim pGeomFactory As IGeometryFactory
                pGeomFactory = New GeometryEnvironment
                Dim pGeom As IGeometry
                pGeom = pGeomFactory.CreateGeometryFromEnumerator(pEnumGeom)
                ' AxPageLayoutControl1.ActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, Nothing, Nothing)
                AxPageLayoutControl1.ActiveView.Extent = pGeom.Envelope
                'AxPageLayoutControl1.ActiveView.FocusMap.MapScale = 5593
                AxPageLayoutControl1.ActiveView.Refresh()
            End If
        Catch ex As Exception
            MsgBox(ex.Message)
        End Try
    End Sub
RuchiraWelikala
I'm not sure exactly where the issue with the your code is, but in VB.NET (not necessarily with a standalone application), I tend to import the ESRI.ArcGIS.Controls assembly into the code and use this to zoom to selected features.
            ' Declare ICommand to use ZoomToSelected tool
            Dim pCommand As ICommand
            pCommand = New ControlsZoomToSelectedCommand
            ' Pass the m_application as an object for the oncreate method
            pCommand.OnCreate(AxMapControl)
            pCommand.OnClick()
            pMxDoc.FocusMap.MapScale = 100000
for the OnCreate method, I generally use the IApplication, but in your case, it might be the AxMapControl.
Give it a try,
Good luck.
NehayaArabeiat
Hi rwelikal,
Thanks for your reply.
I tried your code but it gives me this error:
"Exception from HRESULT: 0x800A0424"
sundareshRamasubramanian
Hi
Can you please explain us on what exactly are you looking at? I dont understand why you are using both layout and map controls.
You please tell us what exactly the process is.
Zooming to a selected feature shouldnt be a problem.
WilliamChristmas
Dim pUID As New UID
    Dim pCmdItem As ICommandItem
    pUID.value = "{AB073B49-DE5E-11D1-AA80-00C04FA37860}"
    pUID.SubType = 3
    Set pCmdItem = Application.Document.CommandBars.Find(pUID)
    pCmdItem.Execute
NehayaArabeiat
Hi
I try your code but I'm working in vb.net and it give me the following error for Application.Document:
"reference to non-shared member requires an object reference".
Is their a way to call commandbars instead from Application.Document??
