Zonal Statistics Error in C# project
1808
09-06-2011 05:42 AM
KarlSiemsen
I'm trying to call the geoprocessor from arcengine in c# code and I keep getting an error. I've used simple file and folder names, and the process works fine in ArcMap, but fails in arcengine. Here is the error message from the geoprocessor:
Zonal statistics program failed
Executing: ZonalStatisticsAsTable C:\testnes\subs.shp AREA_NAME C:\testnes\nonesurr C:\fortis\table6.dbf DATA
Start Time: Tue Sep 06 09:25:46 2011
An error was encountered while executing ZonalStatisticsAsTable.
("esriGeoAnalyst.GridEngine") Zonal statistics program failed
Error in executing grid expression
Failed to execute (ZonalStatisticsAsTable).
End Time: Tue Sep 06 09:25:51 2011 (Elapsed Time: 5.00 seconds)
And here is the source code:
GPHelper.GPZonalStats(@"C:\testnes\subs.shp", @"C:\testnes\nonesurr", "AREA_NAME", @"C:\fortis\table6.dbf");
GPHelper class functions:
public static bool GPZonalStats(string strZoneRaster, string strValueRaster, string strZoneField, string strTable)
            Geoprocessor pGP = new Geoprocessor();
            ZonalStatisticsAsTable zonalStats = new ZonalStatisticsAsTable();
            zonalStats.in_zone_data = strZoneRaster;
            zonalStats.in_value_raster = strValueRaster;
            zonalStats.zone_field = strZoneField;
            zonalStats.out_table = strTable;
            return RunGP(pGP, zonalStats, null);
public static bool RunGP(Geoprocessor geoprocessor, IGPProcess process, ITrackCancel TC)
            // Set the overwrite output option to true
            //Debug.WriteLine(Convert.ToString(geoprocessor.GetEnvironmentValue("Workspace")));
            geoprocessor.OverwriteOutput = true;
            // Execute the tool
            try
                geoprocessor.Execute(process, null);
                return ReturnMessages(geoprocessor);
            catch (Exception err)
                Console.WriteLine(err.Message);
// Function for returning the tool messages.
        private static bool ReturnMessages(Geoprocessor gp)
            if (gp.MessageCount > 0)
                string allMessages = null;
                for (int Count = 0; Count <= gp.MessageCount - 1; Count++)
                    Console.WriteLine(gp.GetMessage(Count));
                    allMessages += gp.GetMessage(Count);
                if (allMessages.Contains("successfully"))
                    return true;
                else return false;
            else return false;
MarilynGambone
Instead of invoking RunGP, have you tried just calling it directly:
pGP.OverwriteOutput = true;
pGP.Execute(zonalOp, null);
