Working with ISurface.Locate method
647
12-13-2011 03:37 AM
MarAlcaraz1
Hi, I need to work with ISurface.Locate method, but the help topic of arcobjects is not enough detailed.
Function Locate( ByVal pRay As IRay, ByVal hint As Long ) As IPoint
I don't understand what hint is.
Otherwise, if I use a ITinSurface, the method returns points in the middle of the tin triangles, is that correct for this method?
Thanks a lot, Mar
