Why is this adding a the new feature class to the mxd?
1120
09-18-2012 06:47 AM
RobertDouglas
I am building a suite of Add-Ins. This one is to make a back up of a selected layer. When the tool is run the backed up feature class is added to the mxd. I don't want it to be added to the map document and I can't figure out why it is being added. Any suggestions?
       public static IWorkspace FileGdbWorkspaceFromPath(String path)         {             Type factoryType = Type.GetTypeFromProgID("esriDataSourcesGDB.FileGDBWorkspaceFactory");             IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)Activator.CreateInstance(factoryType);             return workspaceFactory.OpenFromFile(path, 0);         }          public IFeatureClass GetFeatureClassOfSelectedFeatureLayer(IFeatureLayer featureLayer)         {             IFeatureClass featureClass = featureLayer.FeatureClass;             return featureClass;         }          protected override void OnClick()         {             IWorkspace workSpace = FileGdbWorkspaceFromPath(@"G:\PROJECTS\SCHOOL_SAFETY_MAPPING_APPLICATION_20120606\DATA\SchoolSafety.gdb");             CreateFeatureClass(workSpace, "SelectedLayerBU");         }          public void CreateFeatureClass(IWorkspace workspace, String featureClassName)         {             IFeatureWorkspace featureWorkspace = (IFeatureWorkspace)workspace;              IWorkspace2 pWorkspace2 = workspace as IWorkspace2;              ////Delete the Feature Class if it already exists////             if (pWorkspace2.get_NameExists(ESRI.ArcGIS.Geodatabase.esriDatasetType.esriDTFeatureClass, "SelectedLayerBU"))             {                 FeatureClass featureC = (FeatureClass)featureWorkspace.OpenFeatureClass("SelectedLayerBU");                 IDataset dataSet;                 ISchemaLock schemaLock = (ISchemaLock)featureC;                 dataSet = featureC;                 dataSet.Delete();                 schemaLock.ChangeSchemaLock(esriSchemaLock.esriSharedSchemaLock);             }              IFeatureClass featureSelected = GetFeatureClassOfSelectedFeatureLayer((IFeatureLayer)ArcMap.Document.SelectedLayer);              try             {                 featureWorkspace.CreateFeatureClass("SelectedLayerBU", featureSelected.Fields, featureSelected.CLSID, featureSelected.EXTCLSID, featureSelected.FeatureType, featureSelected.ShapeFieldName, null);                 Geoprocessor gp = new Geoprocessor();                 gp.SetEnvironmentValue("workspace", @"G:\PROJECTS\SCHOOL_SAFETY_MAPPING_APPLICATION_20120606\DATA\SchoolSafety.gdb");                  Append append = new Append(); //this tool uploads the feature class                 append.inputs = featureSelected;                 append.target = @"G:\PROJECTS\SCHOOL_SAFETY_MAPPING_APPLICATION_20120606\DATA\SchoolSafety.gdb\SelectedLayerBU";                  gp.Execute(append, null);              }              catch (Exception exc)             {                 MessageBox.Show(Convert.ToString(exc));                 return;             }
Robbie
NeilClemmons
Honored Contributor
You're using a geoprocessing tool.  The geoprocessing environment has a global setting to automatically add outputs to the map.  You can turn it off, either through the ArcMap UI or through code (IGeoProcessor.AddOutputsToMap).
NeilClemmons
Honored Contributor
RobertDouglas
Thanks Neil. That might have been the fastest answer ever.
