What's wrong in my code?  If you can help?
1697
09-26-2013 08:14 AM
ShaningYu
Honored Contributor
See my code below:
            // fc - a feature class w/ multiple feature records
            ESRI.ArcGIS.Location.RouteEventSourceClass rteEventSourceClass;
            rteEventSourceClass = fc as ESRI.ArcGIS.Location.RouteEventSourceClass;
But the value of the rteEventSourceClass is null.  Did I do something wrong?  I want to retrieve the rteEventSourceClass values.  Thanks.
ShaningYu
Honored Contributor
The cast posted before was not correct.  In stead of
ESRI.ArcGIS.Location.IRouteEventSource rtEvtSourceClass;
rtEvtSourceClass = (ESRI.ArcGIS.Location.IRouteEventSource)fc;
It should be
IFeatureClass fc = (IFeatureClass)rtEvtSourceClass;
Thread is to be closed.
ShaningYu
Honored Contributor
From the ArcObjects diagram (http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#//003100000138000000), it is known that the ESRI.ArcGIS.Location.RouteEventSourceClass is a sub-class of FeatureClass.  In this piece of code below:
            ESRI.ArcGIS.Location.RouteEventSourceClass rtEvtSourceClass = (ESRI.ArcGIS.Location.RouteEventSourceClass)fc;
Got InvalidCastException:  Unable to cast COM object of type 'System.__ComObject' to class type 'ESRI.ArcGIS.Location.RouteEventSourceClass'. COM components that enter the CLR and do not support IProvideClassInfo or that do not have any interop assembly registered will be wrapped in the __ComObject type. Instances of this type cannot be cast to any other class; however they can be cast to interfaces as long as the underlying COM component supports.
Why can't cast here?  Thanks.
ShaningYu
Honored Contributor
As the continuation of 2nd post of the thread, I followed the recommendation in the error message, used interface and then did the casting, like that:
Then, got new error:  Unable to cast COM object of type 'System.__ComObject' to interface type 'ESRI.ArcGIS.Location.IRouteEventSource'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{641755F0-B7DE-11D3-9F7C-00C04F6BDF06}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Then, I opened the Registry Editor to search the {641755F0-B7DE-11D3-9F7C-00C04F6BDF06}.  The result shows that it is at
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\.
For the 'No such interface supported ...', I referred to http://www.huggill.com/2012/09/06/solving-an-exception-occurred-in-publishing-no-such-interface-supp... provided procedure:
1. Run Command Prompt as Administrator
2. regsvr32 actxprxy.dll
3. Restart Visual Studio
The problem is still there and the error message is the same.  What I should do next?  Welcome your suggestion or hint.  Thanks.
by Anonymous User
Not applicable
Make sure your reference to fc is also an interface rather than a class.
While .NET technically supports 'class casting', to ease the transition from VB6, you'll run into all sorts of problems with ArcObjects and COM interop.
ShaningYu
Honored Contributor
It should be
