What object to pass to buffer.dissolve_field?
896
02-06-2014 08:13 PM
LukeNouwens
I am using ESRI.ArcGIS.AnalysisTools.Buffer to buffer a feature and dissolve on two fields. Does anyone know what type of object I need to pass to the .dissolve_field property? I have tried a list object containing field objects but this throws an error on execution of the buffer.
The buffer works if I disable the .dissolve_option property but I really need to buffer and dissolve fields.
Luke
NeilClemmons
Honored Contributor
One of the best ways to find out how to call any of the geoprocessing tools is to run them through the ArcGIS software.  The geoprocessing window for the tool will show the command line arguments as part of the output log.
