What is wrong with this code: pWorkspace.FindVersion
655
01-16-2019 04:26 PM
JoseSanchez
Reposted under ArcObjects group.
pWorkspace = pWorkspaceFactory.OpenFromFile(prefixOutput, 0)
Dim version As IVersion = CType(pWorkspace, IVersion)
Dim versionName As String = version.VersionName
Dim targetVersion As IVersion = Nothing
' check if working with Editor's version
If version.VersionName <> strEditorVersion Then
   targetVersion = CType(pWorkspace.FindVersion(strEditorVersion ), IVersion)   ************  It crashes here
End If
ERROR MESSAGE
Error Message: Object reference not set to an instance of an object.Date1/16/2019
JoseSanchez
I also tried this code and it also fails:
dim version As IVersion = CType(pWorkspace, IVersion)
                Console.WriteLine("versionName: " & versionName)
                ' working with Editor's version
                If version.VersionName <> strAEditingVersion Then
                    Dim VrsWrkSpc = CType(pWorkspace, IVersionedWorkspace3)     FAILS HERE!!!!!!!!!!!
                    targetVersion = VrsWrkSpc.FindVersion(strEditingVersion)
                End If
