I have an application written with C# related to ArcGIS 10.5. Right now we need to upgrade to arcgis 10.6.1, but I need to recompile my source code and found a warning with the ESRI.ArcGIS.ADF.Connection.Local. Here is the warning message:
There was a mismatch between the processor architecture of the project being built "MSIL" and the processor architecture of the reference "ESRI.ArcGIS.ADF.Connection.Local, Version=10.5.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86, processorArchitecture=x86", "x86".
This mismatch may cause runtime failures. Please consider changing the targeted processor architecture of your project through the Configuration Manager so as to align the processor architectures between your project and references, or
take a dependency on references with a processor architecture that matches the targeted processor architecture of your project.
I have no idea how to fix this problem. Anyone has the same issue? Thanks!
Jin
