What is the best way to execute custom code when a version is posted to DEFAULT?
1575
10-25-2010 10:45 AM
JordanParmer
I need to write custom code that compares versions on 'Post'.  I want to compare the edit version being posted to the DEFAULT version prior to the actual edits being committed in DEFAULT.
I've thought of writing a custom Post command for ArcMap, but this requires all of our GIS analysts to have the extension installed (and use it).  That is too much of a training risk.
It would be ideal if I could catch the Post at the database level so that no matter who posts, I can handle the event.
Any ideas on how I might do that (or something similar)?
JamesMacKay
Hi Jordan,
One option would be to create a workspace extension that implements the IVersionEvents2 interface. The major drawback of this is that you'd still have to deploy a DLL to all of your users, but it has the advantage over a custom command that your users can still rely on the standard post command. Once they install the DLL the user experience won't change for them at all.
Here's a link with more information: http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/Creating_workspace_exte...
Cheers,
James
JordanParmer
Hey James,
That is a good idea.  I've been looking into it.  Unfortunately, the way our company is structured, our GIS analysts are somewhat sandboxed from our development group.  There is a likely chance that a new employee will get a machine pre-loaded with a GIS image without our extensions installed.
After thinking on this, I think I'm going to have the GIS analysts post all of their edits to a QA/QC version and then write a custom process that posts that version to DEFAULT allowing me to run custom code comparing the two versions.
Is there a way to prevent people from posting to DEFAULT?
JamesMacKay
I think setting your DEFAULT version's permissions to Protected should give you what you're looking for.
Cheers,
James
JordanParmer
Thanks James!  I'll look into that.
