WFS connector (java)
2028
7
03-26-2010 04:37 AM
TomSchuller
Hy,
Does there exist a WFS connector in the ArcObjects-Api (java).
I wan't to connect me to a WFSserver.
For the WMS, I'm using the "WMSMapLayer". Is there somewhere the equivalent for WFS services?
Tom
PeterSouth
Hi Tom,
I'm facing the very same situation. Have you got a solution?
thanks
TomSchuller
Hy,
I'm actually using some GeoTools code (http://www.geotools.org) for making my WFS communications.
Tom
ShaunMartin
Hi Tom,
I'm trying to do a similar thing using geotools and adding the resulting image to a layer in ArcMap do you have any code solution to do this.
Cheers,
Shaun
TomSchuller
Hy,
are you looking for WMS (image) or WFS (vector).
The WFS does return vectors, not images.
My WFS code is not running in ArcMAP. I'ts a pure GeoTools application without ESRI code.
Tom
ShaunMartin
Thanks for the reply.
So does that mean you are not pushing the results back into say ArcMap?
Shaun
TomSchuller
Hy,
I'm exporting in GetTools the data in a shapefile.
In ArcMAP, I'm working with the generated shapefile.
I don't have a direct interaction between GeoTools objects and ArcObject objects.
Tom
TomSchuller
For connecting in ArcMAP to WFS data, you can use the DataInteroperability extension (I think it's free).
