Weird element behaviour.
933
05-15-2012 05:04 AM
sercanpehlivan
Please help.
I created a multipatch geometry and I want to see it on globe control an correct altitude.Although i gave the same coordinates to both feature and element,
element is shown above the feature .Here is my code
element part
IPointCollection coll = new Polygon();
            ((IZAware)coll).ZAware = true;
            IPointCollection coll2 = new Polygon();
            ((IZAware)coll2).ZAware = true;
            IPoint[] points = new IPoint[8];
            for (int i = 0; i < 8; i++)
                points = new ESRI.ArcGIS.Geometry.Point();
                ((IZAware)points).ZAware = true;
            points[0].PutCoords(27, 41);
            points[0].Z = 100000;
            points[1].PutCoords(27.5, 32.5);
            points[1].Z = 500000;
            points[2].PutCoords(40, 32);
            points[2].Z = 600000;
            points[3].PutCoords(35, 39);
            points[3].Z = 0;
            points[4].PutCoords(27, 41);
            points[4].Z = 500000;
            points[5].PutCoords(27.5, 32.5);
            points[5].Z = 500000;
            points[6].PutCoords(40, 32);
            points[6].Z = 500000;
            points[7].PutCoords(35, 39);
            points[7].Z = 500000;
            coll.AddPoint(points[0]);
            coll.AddPoint(points[1]);
            coll.AddPoint(points[2]);
            coll.AddPoint(points[3]);
            coll2.AddPoint(points[4]);
            coll2.AddPoint(points[5]);
            coll2.AddPoint(points[6]);
            coll2.AddPoint(points[7]);
            IExtrude2 ext = (IExtrude2)new GeometryEnvironment();
            IGeometry geom = ext.Extrude(1, coll as IGeometry);
            IMultiPatch patch = geom as IMultiPatch;
            IExtrude2 ext2 = (IExtrude2)new GeometryEnvironment();
            IGeometry geom2= ext.Extrude(1, coll2 as IGeometry);
            geom2.SpatialReference = geographic;
            IMultiPatch patch2 = geom2 as IMultiPatch;
            IRgbColor color = new RgbColor();
            color.Red = 255;
            color.Green = 0;
            color.Blue = 0;
            //color.Transparency = 20;
            ISimpleFillSymbol simpleFillSymbol = new SimpleFillSymbol();
            simpleFillSymbol.Color = color;
            IElement element = new MultiPatchElement();
            element.Geometry = patch as IGeometry;
            IElement element2= new MultiPatchElement();
            element2.Geometry = patch2 as IGeometry;
            IFillShapeElement fillShapeElement = element as IFillShapeElement;
            fillShapeElement.Symbol = simpleFillSymbol;
            IFillShapeElement fillShapeElement2 = element2 as IFillShapeElement;
            fillShapeElement2.Symbol = simpleFillSymbol;
            //((IGraphicsContainer)m_globeGraphicsLayer).AddElement(fillShapeElement as IElement, 1);
            ((IGraphicsContainer)m_globeGraphicsLayer).AddElement(fillShapeElement2 as IElement, 0);
feature part
Console.WriteLine("dosyaya yazma i??lemi basladi");
            string folder = @"D:\\";
            string nameOfShapeFile = "ff.shp";
            string shapeFieldName = "Shape";
            try
                IWorkspaceFactory workspaceFactory = null;
                workspaceFactory = new ShapefileWorkspaceFactory();
                IWorkspace workspace = workspaceFactory.OpenFromFile(folder, 0);
                IFeatureWorkspace featureWorkspace = workspace as IFeatureWorkspace;
                IFields fields = null;
                IFieldsEdit fieldsEdit = null;
                fields = new Fields();
                fieldsEdit = (IFieldsEdit)fields;
                IField field = null;
                IFieldEdit fieldEdit = null;
                field = new Field();///###########
                fieldEdit = (IFieldEdit)field;
                fieldEdit.Name_2 = "Shape";
                fieldEdit.Type_2 = (esriFieldType.esriFieldTypeGeometry);
                IGeometryDef geomDef = null;
                IGeometryDefEdit geomDefEdit = null;
                geomDef = new GeometryDef();///#########
                geomDefEdit = (IGeometryDefEdit)geomDef;
                ISpatialReferenceFactory3 spatialReferenceFactory = (ISpatialReferenceFactory3)new SpatialReferenceEnvironment();
                geomDefEdit.GeometryType_2 = esriGeometryType.esriGeometryMultiPatch;//esriGeometryPolygon;
                IGeographicCoordinateSystem geographic = spatialReferenceFactory.CreateGeographicCoordinateSystem((int)ESRI.ArcGIS.Geometry.esriSRGeoCSType.esriSRGeoCS_WGS1984);
                geographic.SetDomain(-180, 180, -90, 90);
                geographic.SetZDomain(-10000000000000, 100000000000000);
                geomDefEdit.SpatialReference_2 = geographic;//spatialReferenceFactory.CreateGeographicCoordinateSystem((int)ESRI.ArcGIS.Geometry.esriSRGeoCSType.esriSRGeoCS_WGS1984);
                geomDefEdit.HasZ_2 = true;
                //geomDefEdit.HasM_2 = true;
                fieldEdit.GeometryDef_2 = geomDef;
                fieldsEdit.AddField(field);
                //Add another miscellaneous text field
                fieldEdit.Length_2 = 30;
                fieldEdit.Name_2 = "Id";
                fieldEdit.Type_2 = esriFieldType.esriFieldTypeInteger;
                IFeatureClass featClass = null;
                featClass = featureWorkspace.CreateFeatureClass(nameOfShapeFile, fields, null, null, esriFeatureType.esriFTSimple, shapeFieldName, "");
                IFeature feature = featClass.CreateFeature();
                IPointCollection polygon = new Polygon();
                ((IZAware)polygon).ZAware = true;
                IPointCollection polygon2 = new Polygon();
                ((IZAware)polygon2).ZAware = true;
                points[0].PutCoords(27,41);
                points[1].PutCoords(27.5,32.5);
                points[2].PutCoords(40,32);
                points[2].Z = 500000;
                points[3].PutCoords(35,39);
                points[3].Z = 0;
                polygon.AddPoint(points[0]);
                polygon.AddPoint(points[1]);
                polygon.AddPoint(points[2]);
                polygon.AddPoint(points[3]);
                polygon2.AddPoint(points[4]);
                polygon2.AddPoint(points[5]);
                polygon2.AddPoint(points[6]);
                polygon2.AddPoint(points[7]);
                IGeometry geom = ext.Extrude(1, polygon as IGeometry);
                IGeometry geom2 = ext.Extrude(1, polygon2 as IGeometry);
                feature.Shape = patch;
                feature.Store();
                IFeature feature2 = featClass.CreateFeature();
                feature2.Shape = patch2;
                feature2.Store();
                /*feature.Shape = (IGeometry)patch;//polygon;
                feature.Store();*/
            catch (Exception ex)
                MessageBox.Show(ex.Message);
            Console.WriteLine("dosyaya yazma i??lemi bitti");
why are elemnts drawn the wrong place? What is he way that i can show an element on wanted elevation.
I tried almost everything to correct this situation? Can anyone help me? Thanks in advance.
