website  interactive map
1214
09-05-2012 07:38 AM
MOHAMMEDHABBOUB
Hello developers,
Well, how could I upload my shapefile (with its attribute) in a website as an interactive map (as simple as possible) 🙂
thanks 🙂
MOHAMMEDHABBOUB
Any help? 😮
SachinKanaujia
I hope what you mean is to upload a shapefile and display it as a map. You can use open source stack like Geoserver with Openlayers/GeoExt or MapFish. If you are using ESRI products then you can use their API's to publish a shapefile. Depends on what you are using !!!
ArminMueller
If you are not interested in coding, then you can try Mappetizer which convert your ArcMap project into SVG
