ViperPIN sample "Can't load type library from specified file"
5009
6
07-07-2011 12:12 PM
OlwynBruce
Hi there,
I'm trying to check out the ViperPIN sample and am encountering some problems. I downloaded the VB.NET code, compiled it in VS Express 2008 and registered it using ESRIRegAsm.exe. Then I tried adding it to ArcMap 10 (Customize > Add from file...) and got a "can't load type library from specified file" error.
Any suggestions?
Olwyn
by Anonymous User
Not applicable
Make sure you are adding the .tlb file when you use 'add from file'.
Set ESRIRegAsm.exe to run as administrator before you do this.
OlwynBruce
Hi Sean,
There is no .tlb file. How do I generate one using Visual Studio Express 2008?
Cheers,
Olwyn
by Anonymous User
Not applicable
ok, try the original approach in a command window.
Navigate to the viperpin.dll folder and use:
"C:\Program Files\Common Files\ArcGIS\bin\esriregasm" viperpin.dll
esriregasm.exe must be set to run as administrator (properties->compatibility tab) if you are on a vista or windows 7 machine.
by Anonymous User
Not applicable
You can also generate the .tlb file in VS2008 express by making sure that 'register for COM Interop' is checked in the build tab of the project properties within VS.
You may have to uncheck and recheck this option to ensure its checked as it looks like its in an intermediate state when you first see it.
JOBruceYukon
Test response, please ignore
JOBruceYukon
Second test, continue to ignore
