viewing .pdf file with command button
2584
04-29-2011 07:32 AM
arennaz
I want to add some Help buttons to a user form that will pull up a .PDF or .HTML file that the User can use to learn how to use the form correctly.
i used the code below but get an error says "Only comments may appear after End Sub, End function or End property" . how do I fix this?
Private Declare Function ShellExecute Lib "shell32.dll" Alias _
           "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, _
           ByVal lpFile As String, ByVal lpParameters As String, _
           ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
Private Sub help_Click()
    Dim strFileToOpen As String
    strFileToOpen = "helpfiletoolbox.pdf"
    Dim strFolder As String
    strFolder = "h:\"
    Call ShellExecute(0, vbNullString, strFileToOpen, vbNullString, strFolder, 1)
End Sub
JamesCrandall
I am not sure if the ShellExecute function is completed or not, what code needs to be in it, but it is missing an End Function.  See:
Private Function ShellExecute Lib "shell32.dll" Alias _
'while the End Function below would get rid of your error
'I don't know what (if anything) code should be in this Function
End Function
