VBA to C# Conversion
1982
11-21-2010 02:59 AM
shravanshravan
Could anyone help me in converting the below VBA code into C#, i appreciate for the help you guys do.
Public Sub DumpAttributesToFileExample()
'Open a new text file to write to
Open "c:/temp/outfile.txt" For Output As #1
Dim pMxDoc As IMxDocument
Dim pMap As IMap
Dim pFLayer As IFeatureLayer
Dim pFClass As IFeatureClass
Set pMxDoc = ThisDocument
Set pMap = pMxDoc.FocusMap
'Get reference to layer in table of contents (0 is topmost layer)
Set pFLayer = pMap.Layer(0)
Set pFClass = pFLayer.FeatureClass
'Use a Query Filter to select a subset of features using
'a simple SQL where clause
Dim pQFilter As IQueryFilter
Set pQFilter = New QueryFilter
pQFilter.WhereClause = ""
'Establish a cursor used for looping
Dim pFCursor As IFeatureCursor
Set pFCursor = pFClass.Search(pQFilter, True)
Dim pFeature As IFeature
Set pFeature = pFCursor.NextFeature
'Loop thru all features and write attributes to output file
Do Until pFeature Is Nothing
'Note: below, pFeature.value(1) and pFeature.value(2) use field index numbers of the 2nd and 3rd fields in the table
'to write the values in these fields to output file. Also, the _ character continues an expression to the next line
Print #1, "Field #2 = " & pFeature.Value(1)   & " and Field #3 = " & pFeature.Value(2)
Loop
Close #1
End Sub
JeffreyHamblin
Assuming you are creating an Add-in button, Here is a mostly straight across conversion:
using System;
using System.IO;
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.Geodatabase;
protected override void OnClick()
    DumpAttributesToFileExample("c:/temp/outfile.txt");
private void DumpAttributesToFileExample(string fileName)
    StreamWriter outFile = new StreamWriter(new FileStream(fileName,
                FileMode.Create, FileAccess.Write));
    try
        IMap map = ArcMap.Document.FocusMap;
        IFeatureLayer featureLayer = (IFeatureLayer)map.get_Layer(0);
        IFeatureClass featureClass = featureLayer.FeatureClass;
        IQueryFilter queryFilter = new QueryFilterClass();
        queryFilter.WhereClause = "";
        IFeatureCursor featureCursor = featureClass.Search(queryFilter, true);
        IFeature feature = null;
        while ((feature = featureCursor.NextFeature()) != null)
            string output = "Field #2 = " + feature.get_Value(1).ToString() +
                    " and Field #3 = " + feature.get_Value(2).ToString();
            outFile.WriteLine(output);
    finally
        outFile.Close();
-Jeff
shravanshravan
Thank you Jeff, I appreciate for taking time from your busy schedule and working on this.
AlainHajj
Please can anyone help me in converting this code below for IQueryFilter example from VBA to C#.
Also if anyone can help me to give me a code for IQueryFilter , ISpatialFilter and ITopologicalOperater in C# .
If anyone can reply me on [email protected]
Thank you for your effort and time.
Option Explicit
Enum WorkspaceType
enumGeodatabase = 0
enumPersonalGeodatabase = 1
enumShape = 2
enumCoverage = 3
End Enum
Private Sub Command1_Click()
Dim iWorkspaceConnect As Integer
'Uncomment the Workspace type of choice
'iWorkspaceConnect = enumGeodatabase
'iWorkspaceConnect = enumPersonalGeodatabase
iWorkspaceConnect = enumShape
'iWorkspaceConnect = enumCoverage
On Error GoTo MyError
Dim pPropset As IPropertySet
Set pPropset = New PropertySet
Dim pFact As IWorkspaceFactory
Dim pWorkspace As IWorkspace
Select Case iWorkspaceConnect
Case enumGeodatabase ' Geodatabase (SDE)
With pPropset
.SetProperty "Server", "hephaestus"
.SetProperty "Instance", "sde8_mss"
.SetProperty "Database", "sde"
.SetProperty "user", "sde"
.SetProperty "password", "go"
.SetProperty "version", "sde.DEFAULT"
End With
Set pFact = New SdeWorkspaceFactory
MsgBox "Geodatabase"
Case enumPersonalGeodatabase ' Personal Geodatabase (Access)
pPropset.SetProperty "DATABASE", "d:\\data\\Access Data\\SDETest.mdb"
Set pFact = New AccessWorkspaceFactory
MsgBox "Personal Geodatabase"
Case enumShape ' Shapefile
pPropset.SetProperty "DATABASE", "D:\\data\\SDEtestData\\Greeley"
Set pFact = New ShapefileWorkspaceFactory
MsgBox "Shapefile"
Case enumCoverage ' Coverage
pPropset.SetProperty "DATABASE", "D:\\data\\Coverage"
Set pFact = New ArcInfoWorkspaceFactory
MsgBox "Coverage"
End Select
' Open the Workspace
Set pWorkspace = pFact.Open(pPropset, Me.hWnd)
Dim pFeatureWorkspace As IFeatureWorkspace
Set pFeatureWorkspace = pWorkspace
' Open the FeatureClass
' Coverage data requires that the addition of the geometry type
' when opening the feature class (in this case polgon). The
' feature class name is separated from the geometry type with a
Dim pFeatureClass As IFeatureClass
If iWorkspaceConnect = enumCoverage Then
Set pFeatureClass = pFeatureWorkspace.OpenFeatureClass("parcels:polygon")
Else
Set pFeatureClass = pFeatureWorkspace.OpenFeatureClass("parcels")
End If
Dim pQueryFilter As IQueryFilter
Set pQueryFilter = New QueryFilter
' Set the where clause
pQueryFilter.WhereClause = "SUBTYPE = 'INDSTL'"
' Execute the query filter
Dim pFeatureCursor As IFeatureCursor
Set pFeatureCursor = pFeatureClass.Search(pQueryFilter, False)
Dim n As Long
Dim i As Long
Dim iRecCount As Integer
Dim pPointCollection As IPointCollection
Dim lPnt As Long
iRecCount = 0
' Retrieve the results.
Do
Set pFeature = pFeatureCursor.NextFeature
If Not (pFeature Is Nothing) Then
iRecCount = iRecCount + 1
' Create a list box lstQueryResults and uncoment the next
' five lines to list attributes and values.
' For i = 0 To (pFeature.Fields.FieldCount - 1)
' If Not pFeature.Fields.Field(i).Type = esriFieldTypeGeometry Then
' lstQueryResults.AddItem i & " " & pFeature.Fields.Field(i).Name & " " & pFeature.Value(i)
' End If
' Next i
' Uncoment the next four lines to list feature coordinates.
' Set pPointCollection = pFeature.Shape
' For lPnt = 0 To (pPointCollection.PointCount - 1)
' lstQueryResults.AddItem pPointCollection.Point(lPnt).X & ", " & pPointCollection.Point(i).Y
' Next lPnt
End If
Loop Until (pFeature Is Nothing)
MsgBox iRecCount
Exit Sub
MyError:
If Err.Number <> 0 Then
MsgBox Err.Description
End If
End Sub
JohnHauck
Here are a few links:
ITopologicalOperator
ISpatialFilter
IQueryFilter
I'm afraid this is really just a disservice to you....these conversion exercises are a great opportunity to make connections between some code that you understand and the syntax of a new language you are trying to learn. Regarless I converted the code...but no testing. I hope this helps:
 enum WorkspaceType { enumGeodatabase = 0, enumPersonalGeodatabase = 1, enumShape = 2, enumCoverage = 3 }
        private void button1_Click(object sender, EventArgs e)
            try
                WorkspaceType iWorkspaceConnect = WorkspaceType.enumShape;
          IPropertySet pPropset = new PropertySet();
                IWorkspaceFactory pFact;
                switch (iWorkspaceConnect)
              case WorkspaceType.enumGeodatabase:
                        pPropset.SetProperty("Server", "hephaestus");
                        pPropset.SetProperty("Instance", "sde8_mss");
                        pPropset.SetProperty("Database", "sde");
                        pPropset.SetProperty("user", "sde");
                        pPropset.SetProperty("password", "go");
                        pPropset.SetProperty("version", "sde.DEFAULT");
                        pFact = new SdeWorkspaceFactory();
                        System.Windows.Forms.MessageBox.Show("Geodatabase");
                        break;
                    case WorkspaceType.enumPersonalGeodatabase:
                        pPropset.SetProperty("DATABASE", "d:\\data\\Access Data\\SDETest.mdb");
                        pFact = new AccessWorkspaceFactory();
                        System.Windows.Forms.MessageBox.Show("Personal Geodatabase");
                        break;
                    case WorkspaceType.enumShape:
                        pPropset.SetProperty("DATABASE", "D:\\data\\SDEtestData\\Greeley");
                        pFact = new ShapefileWorkspaceFactory();
                        System.Windows.Forms.MessageBox.Show("Shapefile");
                        break;
                    case WorkspaceType.enumCoverage:
                        pPropset.SetProperty("DATABASE", "D:\\data\\Coverage");
                        pFact = new ArcInfoWorkspaceFactory();
                        System.Windows.Forms.MessageBox.Show("Coverage");
                        break;
                    default:
                        break;
                IWorkspace pWorkspace = pFact.Open(pPropset, 0);
                IFeatureWorkspace pFeatureWorkspace = (IFeatureWorkspace)pWorkspace;
                IFeatureClass pFeatureClass;
                if(iWorkspaceConnect == WorkspaceType.enumCoverage)
                    pFeatureClass = pFeatureWorkspace.OpenFeatureClass("parcelsolygon");
                else
                    pFeatureClass = pFeatureWorkspace.OpenFeatureClass("parcels");
                IQueryFilter pQueryFilter = new QueryFilter(){ WhereClause = "SUBTYPE = 'INDSTL'" };
                IFeatureCursor pFeatureCursor = pFeatureClass.Search(pQueryFilter, false);
                IFeature pFeature = pFeatureCursor.NextFeature();
                int iRecCount = 0;
                while (pFeature != null)
                 iRecCount +=1;
         catch (Exception ex)
                MessageBox.Show(ex.Message);
AlainHajj
Thank you lot for your time. I appreciate your effort.
I want to write a code in C# for searching the nearest point of interest of a object for a camera on the map. For that reason I am asking for a sample C# code for buffering or spatial filter or something else. So if I can get a help in this urgently because I don't have much time for my project. Thank you.
