VBA: Need help finding the resolution (DPI/cellsize) of an arbitrary raster
749
01-03-2012 10:19 AM
ChrisWelch
Hi all.
I'm looking for a way to read the DPI of a raster in ArcObjects. I have the layer loaded up in ArcObjects as an IRasterLayer. Using this, I can find the width and height of the image, the "DisplayResolutionFactor", and other great information, but not the actual DPI of the image.
Is there an easy way to get this information? Everything I find online seems to deal with exporting, but I just want to know if the image is 300dpi, 1200dpi, 2400dpi, etc. Any thoughts?
DuncanHornby
MVP Notable Contributor
Chris,
I'm not too hot on this subject but I've always understood dpi (dots per inch) as something that output devices use (printers/screens) so dpi has no meaning when you look at a raster and is probably why there is no interface that exposes such a property.  I came across this web page which tries to explain what dpi is.
Your thread title also suggests you want to know about cell size, if so then use the interface IRasterInfo.
Duncan
