VBA Add Point so Shape - Zoom Error
760
05-04-2010 09:36 AM
HendrikPischel
i just want to add a single Point Feature to a FeatureClass.
If got this Shape File.
Datatyp: Shapefile Feature Class
Shapefile: ...\Adresse.shp
Geometrietyp: Point
Layername:       > 1:2000
    Dim pMxDocument As IMxDocument
    Dim pMap As IMap
    Dim pLayer As ILayer
    Dim pFeatureLayer As IFeatureLayer
    Dim pFeatureClass As IFeatureClass
    Dim pFeature As IFeature
    Dim pPoint As IPoint
    Dim pEditLayers As IEditLayers
    Dim pEditor As IEditor
    Set pMxDocument = Application.Document
    Set pMap = pMxDocument.FocusMap
' this Function searches for the layer named ... and returns the ILayer.
    Set pLayer = FindeLayer("> 1:2000", pMap)
    Set pFeatureLayer = pLayer
    Set pFeatureClass = pFeatureLayer.FeatureClass
    Set pFeature = pFeatureClass.CreateFeature
    Set pPoint = New Point
    pPoint.PutCoords gbl_SuchQdr_M_X, gbl_SuchQdr_M_Y
    Set pFeature.Shape = pPoint
    pFeature.Store
    pMxDocument.ActivatedView.Refresh
In the End of this i have a Point added to my shape file. But if i check the layers extends these are not limited to the the point coordinates and if i try to zoom to the layer it's only displayed at a very high range.
If i just delete the point and place it with the ArcGIS Edit function there is no zooming error.
So far i think something is worng with my code - can you help me?
Regards,
Hendrik
HendrikPischel
Well i just found a way to fix the error but i'm not sure if i realy need this.
Public Sub AddAdresseToLayer()
    ' In den Layer der Adressen den aktuellen Punkt der Adresse einfügen
    Dim pMap As IMap
    ' Layer suchen
    Set pLayer = FindeLayer("Adresse", pMap)
    ' FeatureClass zuweisen
    ' Workspace öffnen und Edit session starten
    Dim pDataset As IDataset
    Set pDataset = pFeatureClass
    Dim pWorkspace As IWorkspace
    Set pWorkspace = pDataset.Workspace
    Dim pWorkspaceEdit As IWorkspaceEdit
    Set pWorkspaceEdit = pWorkspace
    pWorkspaceEdit.StartEditing True
    pWorkspaceEdit.StartEditOperation
    ' Feature & Punkt erzeugen
    ' Punkt in Feature einfügen
    ' Feature speichern
    pFeature.Store
    ' Edit beenden
    pWorkspaceEdit.StopEditOperation
    pWorkspaceEdit.StopEditing True
End Sub
I thought that i didn't need the edit session.
Regards, Hendrik
