VB.net Walkthrough for Arc10 help
1038
07-19-2010 10:58 AM
RyanFurlong
Hey everyone I am doing the walk through located;
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/Walkthrough_Building_cu...
my issue is when I enter my code for the for the first section as so;
Public Class Button1
    Inherits ESRI.ArcGIS.Desktop.AddIns.Button
    Public Sub New()
    End Sub
    Protected Overrides Sub OnClick()
        ZoomToActiveLayerInTOC(TryCast(ArcMap.Application.Document, IMxDocument))
    End Sub
    Protected Overrides Sub OnUpdate()
        Enabled = My.ArcMap.Application IsNot Nothing
    End Sub
End Class
I get an error saying I did not declare
ArcMap.
and
IMxDocument
how do I fix this?  The walk through does not say anything about making declarations.  BTW I am using Visual Studio 2008 express.  Thank you for the help.
RyanFurlong
Never mind I figured it out.
JeffArnett
Greetings,
I am experiencing the exact same issue.  Could you kindly share your solution?
Regards,
Jeff
MichaelRobb
Honored Contributor
When you Inherit Addins.Button.
MY namespace can be used.
