VB.Net - Interacting with Form in ArcMap
1479
08-03-2010 07:59 AM
NeedHelp
I've read countless posts and other info...however I just can't wrap my head around how to have a form interact with ArcMap.
My Form has 2 list boxes.
Box #1 - lists themes in View (works fine, cuz box gets populated before form is shown)
Box #2 - lists the fields from the theme selected in box #1 (Don't know how to do this!!!)
On form load, I seem to run into issues when I run GetActiveView,GetMxDocument, etc...
Is anyone able to attach this type of small (...and I hope simple)project, to help me out??
KenBuja
MVP Esteemed Contributor
In this example, I have a form with two comboboxes. The first (cboPointLayer) contains the point layers in the view and the second (cboField) contains the fields of the selected layer. The Form_Initialize function populates cboPointLayer and when the user selects a layer, the subroutine cboPointLayer_SelectedIndexChanged populates cboField.
Public Class SelectionForm
  Private m_App As ESRI.ArcGIS.Framework.IApplication
  Private pMxDoc As ESRI.ArcGIS.ArcMapUI.IMxDocument
  Private pEnumLayers As ESRI.ArcGIS.Carto.IEnumLayer
  Private pFLayer As ESRI.ArcGIS.Carto.IFeatureLayer
  Friend Function Form_Initialize(ByVal m_application As ESRI.ArcGIS.Framework.IApplication) As Boolean
    Dim pLayer As ESRI.ArcGIS.Carto.ILayer
    Dim pFLayer As ESRI.ArcGIS.Carto.IFeatureLayer2
    m_App = m_application
    pMxDoc = CType(m_App.Document, ESRI.ArcGIS.ArcMapUI.IMxDocument)
    cboPointLayer.Items.Clear()
    cboField.Items.Clear()
    If pMxDoc.FocusMap.LayerCount > 0 Then
      pEnumLayers = pMxDoc.FocusMap.Layers
      pLayer = pEnumLayers.Next
      Do Until pLayer Is Nothing
        If pLayer.Valid Then
          If TypeOf pLayer Is ESRI.ArcGIS.Carto.IFeatureLayer Then
            pFLayer = pLayer
            If pFLayer.ShapeType = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPoint Then
              cboPointLayer.Items.Add(pLayer.Name)
            End If
          End If
        End If
      Loop
    End If
    Return True
  End Function
  Private Sub cboPointLayer_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cboPointLayer.SelectedIndexChanged
    Dim pFields As ESRI.ArcGIS.Geodatabase.IFields
    Try
      pEnumLayers.Reset()
        If pLayer.Name = cboPointLayer.Text Then
          pPointFLayer = New ESRI.ArcGIS.Carto.FeatureLayer
          pPointFLayer = pLayer
          Exit Do
        End If
      Loop
      pFields = pPointFLayer.FeatureClass.Fields
      For i As Integer = 0 To pFields.FieldCount - 1
        If pFields.Field(i).Type < 6 Then 'this adds only numeric, date, and string fields, not geometry, Blobs, raster, GUID, Global ID, or XML fields.
          cboField.Items.Add(pFields.Field(i).Name)
          ListBox1.Items.Add(pFields.Field(i).Name)
        End If
      EnableRun()
    Catch ex As Exception
     Messagebox.Show(ex.message, "Point Layer")
    End Try
  End Sub
End Class
NeedHelp
Thanks for the quick reply Ken!!
I created a new Toolbar,command and Form.
The Form I created was called Form1, and has the same controls and names as your 2 combo boxes, and list boxes from your example.
I c&p your code. However the combo boxes don't populate (point layers are in the TOC).
(modified your code from "Friend Fucntion Form_Initialize" to "Friend Function Form1_Initialize")
What is the code you used to call the form?
Mine is:
Public Overrides Sub OnClick()
        Dim theform As New Form1
        theform.ShowDialog()
    End Sub
Again thanks for any help/assistance you can provide.
KenBuja
If you notice in the Form_Initialize code, it's expecting IApplication to be passed to it. Here's the OnCreate and OnClick subroutines. I'm also using a a class that sets ArcMap as the form's parent, as mentioned in this thread.
  Private m_application As IApplication
  Public Overrides Sub OnCreate(ByVal hook As Object)
    If Not hook Is Nothing Then
      m_application = CType(hook, IApplication)
      'Disable if it is not ArcMap
      If TypeOf hook Is IMxApplication Then
        MyBase.m_enabled = True
      Else
        MyBase.m_enabled = False
      End If
    End If
    ' TODO:  Add other initialization code
  End Sub
    Dim SelectionForm As New myApp.SelectionForm
    Try
      If Not SelectionForm.Form_Initialize(m_application) Then Exit Sub
      SelectionForm.ShowDialog(New Win32HWNDWrapper(m_application.hWnd))
      MessageBox.Show(ex.Message, "OnClick")
    End Try
  End Sub
NeedHelp
That was exactly what I needed!!!
Thank you very very much Ken.
ps. I think I owe you at least one 'beverage' 🙂
