vb.net arcobjects create transparent buffer
4868
09-07-2014 07:14 PM
LiYao
Hi all,
I want to check when a create a buffer on arcmap, how can I make the buffer transparent? I am using vb.net arcobjects.
Any advice will be appreciated.
RiverTaig1
Actually you can get something that is pretty close to transparency on the ISymbol interface.  So let's say you have created a  graphic element (a IFillShapeElement could be a polygon or a rectangle as shown below).  You will then find the  the  ISymbol:ROP2 and by setting it equal to esriROPMaskPen, it makes for a nice semi-transparent fill.
    Dim fillShapeEl As IFillShapeElement
    Set fillShapeEl = rect
    Dim sfs As ISimpleFillSymbol
    Set sfs = New SimpleFillSymbol
    Dim rgb As IRgbColor
    Set rgb = New RgbColor
    rgb.Red = 255
    'rgb.Transparency = 50 'This doesn't behave as expected...still 100% opaque
    Dim sym As ISymbol
    Set sym = sfs
    sym.ROP2 = esriROPMaskPen 'This is the magic line!!
    sfs.Color = rgb
    fillShapeEl.Symbol = sfs
    gc.AddElement rect, 0
DuncanHornby
MVP Notable Contributor
Li,
Assuming your buffer exists in a layer and is not just some polygon then you can use the interface ILayerEffects to alter the transparency. Only layers support transparency, so if you were intending to create a polygon buffer and display it as a graphic then that will not work.
Duncan
LiYao
Hi Duncan,
Thanks for the reply. I have already create a transparent buffer (for polygon), but now I am unable to remove the colour of the boundary of the buffer.
RiverTaig1
    rgb.Red = 255
    Dim sym As ISymbol
    Set sym = sfs
    sfs.Color = rgb
LiYao
Hi Duncan & Taig,
I have already resolved the issue, thanks a lot for the attention and help.
