VB.net ArcMap AddIn migrated to 10.7 does not stop at Debug
1148
06-18-2020 08:02 AM
JoseSanchez
Hello everyone,
Configuration:
 - AddIn Editor extension
 - VS Visual Basic  2017
-  ArcGIS 10.7.1
I migrated a Vb.Net ArcMap AddIn application to a new desktop with ArcGIS 10.7.1 and VS 2017, and installed ArcObjects_SDK_for_NET_Framework_1071_169617.
The addIn is not working, so I am trying to debug it.
When I run the .Net application in Debug mode, as soon as ArcMap starts opening (splash  screen),  breakpoints change from a solid red circle and a hollow (white filled) circle.
I also tried to display a msgbox on  event " Protected Overrides Sub OnStartup()" when the editor is loaded and it does not show.
What else can I check.
Please advice
JoseSanchez
This is what I did to fix it:
  1. I created a new ArcMap AddIN project  in VB.Net 2017 using  template Desktop-Add-ins--> ArcMapAdd-In
  2. Run it once adn it worlked
  3. compared all option for the new working version with my existing project and in the Debug for solution platmfosm I selected "Any CPU"
  4. The tested again, it worked  once and it stopped working.
  5. After reading other posts, one recommended to reboot my workstation
  6. It works now
