Using Geoprocessing tools in VBA
2905
8
11-09-2009 06:42 AM
JeanJuengling
When trying to import some 9.3.1 VBA code in 9.4, I get a run-time error '21474672559 (80004005)' on the GP.Toolbox line below:
Dim GP As Object
Set GP = CreateObject("esriGeoprocessing.GpDispatch.1")
GP.Toolbox = "C:\Program Files\ArcGIS\Desktop9.4\ArcToolbox\Toolboxes\Analysis Tools.tbx"
Is it still possible to access the geoprocessing tools this way?
RalfGottschalk
Yes it will be possible to create the Geoprocessor this way at 9.4.  However, this does not work right now at Beta 1.  This is a known issue and the tracking number is NIM049770.
curtvprice
I'm having the same issue with beta 1 using script tools written in vbscript that access the geoprocessor through gpdispatch.
You can add me to the list!
curtvprice
Still having this problem. Error popup message follows:
Could not create object named "esriGeoprocessing.GPDispatch.1".
ArcMap 10.0 PR 1 (Build 2348)
jessieleo
I was told that ARCGIS 9.4(10) doesnot support VBA anymore. is it right?
Jessie
curtvprice
Jesse, VBA is supported, but requires a special install.
In truth, I'm trying to use VBScript, not VBA. Can someone help?
JohnHauck
I've also tested this issue at the current build 2396 and it's still a problem. It was fixed for build 2217 but is now a problem again. I will provide some additional information as soon as possible.
JohnHauck
After further investigation I found out that this is a known issue (NIM057021) that the problem came up again and should be resolved for the final build.
curtvprice
Jim, i would be happy to test a patch if that will help. This is needed functionality!
