Using a custom dll (can IHookHelper interface with IMxDocument?)
2327
04-08-2010 08:53 AM
AdrianWelsh
MVP Honored Contributor
Hi all. I am new to using VB.NET to make a custom dll and have looked at lots of examples online.  I found one that uses the hookhelper object to get to ArcGIS (from the IHookHelper interface).  This seems to work fine but I want to be able to access the IMxDocument interface and these 2 objects don't seems to "query interface" together.
I want this code to have a button on ArcMap that opens a form.  The example code I found for this may be a little outdated but this is what I have so far for initializing it.  Can anyone point me in the direction on how to get to the IMxDocument interface?  Or maybe a new example code on custom dlls?
Imports System.Runtime.InteropServices
Imports System.Drawing
'Imports ESRI.ArcGIS.ArcMapUI
'Imports ESRI.ArcGIS.Carto
'Imports ESRI.ArcGIS.Framework
'Imports ESRI.ArcGIS.Geometry
Imports ESRI.ArcGIS.SystemUI
Imports ESRI.ArcGIS.ADF.BaseClasses
Imports ESRI.ArcGIS.ADF.CATIDs
Imports ESRI.ArcGIS.Controls
''' <summary>
''' Summary description for VisualizationBtn.
''' </summary>
<ComClass(VisualizationBtn.ClassId, VisualizationBtn.InterfaceId, VisualizationBtn.EventsId)> _
Public NotInheritable Class VisualizationBtn
    Inherits BaseCommand
    Private m_hookHelper As IHookHelper
#Region "COM GUIDs"
    ' These  GUIDs provide the COM identity for this class
    ' and its COM interfaces. If you change them, existing
    ' clients will no longer be able to access the class.
    Public Const ClassId As String = "670d215e-8631-40f1-a0f4-5cc6d52ce8fa"
    Public Const InterfaceId As String = "8058e6e6-a106-40af-8d89-14b13c2aae8b"
    Public Const EventsId As String = "4ce420bc-5909-4f6c-8a2f-913ecf2ea422"
#End Region
#Region "Component Category Registration"
    '<ComRegisterFunction(), ComVisibleAttribute(False)> _
    'Public Shared Sub RegisterFunction(ByVal regKey As String)
    '    MxCommands.Register(regKey)
    'End Sub
    '<ComUnregisterFunction(), ComVisibleAttribute(False)> _
    'Public Shared Sub UnregisterFunction(ByVal regKey As String)
    '    MxCommands.Unregister(regKey)
    'End Sub
#End Region
#Region "COM Registration Function(s)"
    <ComRegisterFunction(), ComVisible(False)> _
    Private Shared Sub RegisterFunction(ByVal registerType As Type)
        ' Required for ArcGIS Component Category Registrar support
        ArcGISCategoryRegistration(registerType)
        ' TODO: Add any COM registration code here
    End Sub
    <ComUnregisterFunction(), ComVisible(False)> _
    Private Shared Sub UnregisterFunction(ByVal registerType As Type)
        ArcGISCategoryUnregistration(registerType)
        ' TODO: Add any COM unregistration code here
    End Sub
#Region "ArcGIS Component Category Registrar generated code"
    ''' <summary>
    ''' Required method for ArcGIS Component Category registration -
    ''' Do not modify the contents of this method with the code editor.
    ''' </summary>
    Private Shared Sub ArcGISCategoryRegistration(ByVal registerType As Type)
        Dim regKey As String = String.Format("HKEY_CLASSES_ROOT\CLSID\{{{0}}}", registerType.GUID)
        ControlsCommands.Register(regKey)
    End Sub
    ''' <summary>
    ''' Required method for ArcGIS Component Category unregistration -
    ''' </summary>
    Private Shared Sub ArcGISCategoryUnregistration(ByVal registerType As Type)
        ControlsCommands.Unregister(regKey)
    End Sub
#End Region
#End Region
    ' A creatable COM class must have a Public Sub New()
    ' with no parameters, otherwise, the class will not be
    ' registered in the COM registry and cannot be created
    ' via CreateObject.
    Public Sub New()
        'MyBase.New()
        MyBase.m_category = "VB.NET Visualization"
        MyBase.m_caption = "VB.NET Visualization"
        MyBase.m_message = "Display the visualization form"
        MyBase.m_toolTip = "VB.NET Visualization"
        MyBase.m_name = "Developer Samples_FullExtent VB.NET"
        Try
            Dim bitmapResourceName As String = Me.GetType().Name & ".bmp"
            MyBase.m_bitmap = New Bitmap(Me.GetType(), bitmapResourceName)
        Catch ex As Exception
            System.Diagnostics.Trace.WriteLine(ex.Message, "Invalid Bitmap")
        End Try
    End Sub
    ''' <summary>
    ''' Occurs when this command is created
    ''' </summary>
    ''' <param name="hook">Instance of the application</param>
    Public Overrides Sub OnCreate(ByVal hook As Object)
        If hook Is Nothing Then
            Return
        End If
        If m_hookHelper Is Nothing Then
            m_hookHelper = New HookHelperClass()
        End If
        m_hookHelper.Hook = hook
    End Sub
    ''' <summary>
    ''' Occurs when this command is clicked
    ''' </summary>
    Public Overrides Sub OnClick()
        If Nothing Is m_hookHelper Then
            Return
        End If
        If m_hookHelper.FocusMap.LayerCount > 0 Then
            Dim visualizationFrm As VisualizationFrm = New VisualizationFrm(m_hookHelper)  'VisualizationFrm(m_hookHelper)
            visualizationFrm.Show()
        End If
    End Sub
End Class
And the this is part of the code I have written when the form is opened:
Imports System.Windows.Forms
Public Class VisualizationFrm
    Private m_pMxDoc As IMxDocument
    Private m_pMap As IMap
    Private m_pApp As IApplication
    Private m_hookHelper As IHookHelper = Nothing
    Public Sub New(ByVal hookHelper As IHookHelper)
        InitializeComponent()
        m_hookHelper = hookHelper
    End Sub
End Class
Thanks!
KirkKuykendall
Have you tried this?
        m_pApp = m_hookHelper.hook
End Sub
AdrianWelsh
Thanks Kirk, that's exactly what I needed (I think).  Is there any way to give points on this forum?
