Upgrading from 10.1 to 10.3.1 and getting an error on 'GraphicTrackerClass'
2798
08-19-2015 03:46 PM
DarcyHathaway
I am trying to upgrading from 10.1 to 10.3.1 and getting an error "Interop type 'GraphicTrackerClass' cannot be embedded. Use the applicable interface instead."
I updated all the after updating all the References and an coding in Visual Studio 2013.
Here is the code that is failing:
'Initialize the GraphicTracker with the Map
               m_graphicTracker = New GraphicTrackerClass()
               m_graphicTracker.Initialize(TryCast(m_mapControl.Map, IBasicMap))
I have tried just removing the Class like this:
m_graphicTracker = New GraphicTracker()
But then I get the error : Cannot embed interop type 'ESRI.ArcGIS.EngineCore.IActiveViewEvents_Event' because the source interface 'ESRI.ArcGIS.Carto.IActiveViewEvents' referenced by its ComEventInterfaceAttribute cannot be found.
by Anonymous User
Not applicable
It sounds like you have "Embed Interop Types" set to true for the EngineCore assembly which is a feature of .NET 4.x. Try setting the .NET target framework to 3.5 in the project properties.
